LT4 HotCam work with gear drive?
I'm going to be adding the fastburn 385 heads and a lt4 hot cam on a 99 vortec 5.7. Haven't done to much research on whether I can get a gear drive for this cam or not. If anyone knows it may save me some research time.
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
Originally Posted by 85s10blazer
I'm going to be adding the fastburn 385 heads and a lt4 hot cam on a 99 vortec 5.7. Haven't done to much research on whether I can get a gear drive for this cam or not. If anyone knows it may save me some research time. ![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
Lastly the gear drive tends to put and upward force as the gears spin and tend to beat up on the top of the front cam bearing. Stick with a good chain set up and you will be happier and have more money in your pocket
Talking with my dad's friend a while back. He just developed a belt drive system for old chryslers.(no one made them, not even jesel). He's had ten made ($1600 a pop) and all are already sold to people racing chryslers. Anyways, he dyno tested a timing chain, gear drive, and belt drive system, on a sbc 350.(don't know specs, but built) On there engine, the belt drive system made more than both gear and chain, but the chain made more power than the gear drive. Belt was 25 hp more than chain and 40hp more than gear drive. Had no idea could be that much. He said gear drives are good for racing, but not for street cause they soak too much power and generally not needed. Don't know whether yours is for race or street, but just thought I'd let you know(if you didn't already).
