New Pacesetter Longtube Install
Old Nov 19, 2004 | 07:59 AM
BRENTT94Z's Avatar
Default New Pacesetter Longtube Install
Just purchased the Ceramic coated Pacesetter LT's
and on the Driver side, the end of the collector sets up in the body cavity about 1 inch higher than the body brace that the fuel lines run behind. There is no way I can slip the Y pipe on this. Anyone have this problem yet, and is this typical for any LT's?
Old Nov 19, 2004 | 04:05 PM
BRENTT94Z's Avatar
Ok guys, surely Im not the only one w/ this problem. Has anyone ever cut the body brace to fit LT's. I dont see it being a problem as long as you rebrase it.
Old Nov 20, 2004 | 01:33 AM
Nasty_T/A_GT's Avatar
I had the same thing, I bent the header down a bit by sticking a pipe in there and giving it one helluva a tug.
Old Nov 21, 2004 | 09:32 PM
NXSLT1's Avatar
I just put my pacesetters on a couple weeks ago and had the same prob. I bent the drivers side down a little bit with a 2x4. I don't have a y pipe anymore, went with duals so I can't help ya there. The reducer was a very tight fit though, maybe a half inch to an inch of clearance.
Old Dec 12, 2004 | 09:48 PM
fastenough's Avatar
Check your motor mounts
Old Dec 17, 2004 | 06:45 PM
Poik's Avatar
I have Pacesetter LTs and the driver's side header is very close to the frame. After I had a y-pipe custom fabbed and welded on, I can't really find a way to bend it down..
Old Dec 17, 2004 | 08:48 PM
NXSLT1's Avatar
Try gettin a 2x4 or a bar in between the frame and the header collector and try to pry it down. I had to use a 2x4 after using a steel bar. I thought I had it bent down good enough but when I got the duals put on it was still a little too close. Let the headers warm up, that'll make them bend easier.
Old Dec 17, 2004 | 08:55 PM
Poik's Avatar
The only thing I can get in between the frame and the header is the tip of a prybar. No leverage though! I think I'm going to have to wait until the next time it is up on a lift. Although I might try heating the headers up, that's a good idea, thanks!
Old Dec 18, 2004 | 11:11 AM
BRENTT94Z's Avatar
You need to drop your Tranny Crossmember to get the 2x4 between the body and the y pipe. Then Take a jack and place it under the trans and jack it back up w/ the 2x4 still lodged between. Thats what I did and now id clears everything just fine.
