LT1 Engine Questions
Old Nov 23, 2004 | 10:32 PM
ShadowStorm7's Avatar
Default LT1 Engine Questions
I have a few questions that needs answers? any info is greatly appreciated.
1. Before I tore my motor down there was a nocking noise, but when I tore it down there was nothing broke or unusual looking inside of the motor?
2. The block looks good and measures up good I just dont know if I need to have it machined for anything?
3. What all should I replace while building it, I am going to the LT4 Hot Cam Kit for sure, so what else should I replace?
4. Where can I get a good rebuild kit for the LT1?
5. Whats a good clutch to put in it?
Old Nov 24, 2004 | 10:48 AM
Ls1LikeNoOther's Avatar
If you got it all apart you might as well go all out...Order the Fel-Pro gasket set,order new rings new bearings everywhere and just reseal the motor itll be a lot happier.
It would be good if you took the block to a machine shop and at least had them run a clean up bore on it.That way the rings have a nice hatch to seat with.
Old Nov 24, 2004 | 11:43 AM
ou812/z28's Avatar
i second that........
Old Nov 30, 2004 | 04:21 PM
~JOSHUA's Avatar
IF YOU CAN, UPGRADE THE ROCKER ARMS TO FULL ROLLERS,AS FAR AS CLUTCHES GO.. FOR THE 4TH GEN SPEC SEEMS TO BE THE BEST.
Old Nov 30, 2004 | 04:34 PM
Poik's Avatar
Can you please stop talking in ALL CAPS?
Lots of people tend to have problems with the Spec clutches, and the McCleod Street Twin has had a lot of good reviews holding up to 1000hp.
Old Nov 30, 2004 | 05:28 PM
~JOSHUA's Avatar
YES MOMMY, I CAN STOP USING CAP LOCKS
Old Nov 30, 2004 | 07:55 PM
Scott96LT1's Avatar
Why not go with something better than the hotcam? Combination Motorsports has nice affordable cam kits that have much more to offer than the hotcam.
www.cmotorsports.com
Old Dec 2, 2004 | 10:13 PM
I need something that will pass emmissions and I got a great deal on the hot cam from a friend. Doesnt the hot cam have full rockers.
