LT4 Hotcam kit on 97z?
With full boltons, I would expect 320 RWHP properly tuned with stock heads. If you get the heads ported, you could see up to 350-360 RWHP. For street use, the 2300 stall would be great. I am running the LT4 Hotcam with ported heads in my Vette. DEFINATELY get those gears. I run my stock 2.59s (for now anyway) and it kills me at the track.
The only problem I had with my setup was some fouled spark pluggs due to a bad tune.
Since my 92 uses the old speed density based ECU, I contacted Alvin at PCMforless and told him what mods I had. He sent me a piggyback chip that fixed the problem.
Your 97 will be running MAF AND an OBDII engine management system that is harder to tune. There is a guy a pcmforless that does all the 94-97 LT1 tunes named Brian.
230/244 Duration @0.05 inches lift, 0.544/0.576 inches lift with 1.6/1 rockers and 112 LSA
there are a couple other options in the line of heads/cam if you want to go that direction. lloyd elliott makes a heads/cam package that will put you anywhere from 370-390 rwhp with good tuning, AND it'll pass emissions if that's a concern.
It's all nice to say get this cam or get that cam but you should really match your cam to your heads. No reason to have heads that are choked up top and run a high lift cam.
