LT1 aluminum carburator intake?
Hi i was wondering if the LT1 aluminum carburator intake from GM Performance parts was good, if it hurt, helped or didnt make any changes to the performance of the motor, thanks.
Originally Posted by z28boysteve
if your gonna want all out, go for an edelbrock Victor SBC intake and MAKE it fit. then fuel inject that...
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
I use this intake and i feel it is very good as is. this is a high rise dual plane design. you can also modify it for future mods. like carb.spacers or removing 1/2" from center divider whn more HP/ RPM is needed. whats great about this intake is (compred to gen1 sbc) theres no coolant or exh. crossovers going through it. just air and fuel, which makes for a much denser charge. my prev. combo went 13.7 @104.20 with a 30k stock 93 LT1 in a 3600LB 4-spd car (79 cutlass) spinning first w/street tires. 2.01 best 60ft. yuck! must get traction!
Ditto on converting a single plane, thats what i did. Do a search on cz28 for lt1 single plane, all the info is there.
http://memimage.cardomain.net/member...06_14_full.jpg
It also has the advantage of bolting right up to the stock heads with no modifications, as apposed to an Edelbrock Victor Jr which requires you to drill holes into your cylinder heads to match the bolt pattern on the intake and weld up the old ones. Probably not the easiest in the world thing to do.
The GMPP duel plane also has the advantage of being able to use a carb and still have enough clearance to fit under the stock hood. With the Edelbrock, you can expect to have to cut a chuck out of your dash in order to get it to fit. You'd also have to forget about the stock hood. You'd need a cowl induction for the neccessary clearance.
If your building an all out race motor, then by all means, go with the Edelbrock, it's not like you'd care to much about hood clearance or cutting up the car anyways
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Just for the record, I'm going to be picking up the GMPP LT4 carb intake and grinding out an 1' or so out of the divider and possibly adding a spacer (depends on clearance) for my 396 build-up. It won't be a "true" single plane, but it will have almost the same top end but with overall higher torque throughout the lower to mid RPM's. It's going to be a "serious" street car, but NOT a race car. I'd go with the edelbrock if it was.
Originally Posted by 17WITHaBIRD
when adding the carb intake what do you do with the computer? is it still needed and left in the car?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
No more black box stuffed in the corner of the engine compartment. No more wireing harness. No more sensors. NO MORE OPTISPARK
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
thanx everybody for the very much needed help. if anybody has anymore in put its very much appreciated. also on the edelbrock intake, where the intake meets the head, is that the same angle?
Originally Posted by iroc89
Is there anyway i can get hp out of the GMPP intake, if not is it just basicly redrilling 27 deg. holes on the edelbrock.
That's the route I'm taking and it's a hell of a lot easier then re-drilling new bolt-holes on your heads to match those of the Edelbrock Victor intake. What happens if the holes aren't drilled properly? You'd better have the $$ for new heads ! Do you really know somebody you trust enough to do a job like that perfectly the first time?? Your call.....
The dual plane from GM is to switch over to a carb. The Edelbrock Victor E single plane has bungs already for the injectors and they will fit, all you have to do is make a plate that goes over the thermostat since you wont be using it. Also you have to drill holes to make it bolt to the lt1 castings but it fits just fine. That would be your best bet....
Nevermind, I didnt read the complete post. The dual plane should work fine, I also have a new one in its box in my garage.
ok so the GMPP intake is a dual plane and by grinding out the center section i can make it a single plane, do i have that correct. and with a single plane and a carb spacer i can get more horsepower. is that corect from what i've been reading. just wanna make sure i got the right info.
Generally, rule of thumb is, single planes sacrifice low to mid range torque for high RPM horsepower. Duel planes, are the opposite. They'll sacrifice a bit on the top end, but tend to make more torque in the lower to mid range.
The way I see it, it's easier to get a duel plane to flow better at higher RPM's (using the method's already mentioned) then it is to get a huge single plane to make more power down low.
Be honest with yourself and what your goals are for your car. If it's going to be an all out race car, go with the single plane. It'll flow more then the duel no matter what you do to it.
If it's a street car, I'd say go with the duel plane. I don't see why anyone would want to loose out on low end torque just to make a few more horses at 7000 or whatever RPM. How often are you spinning the motor that fast anyway on the street?
Race Car = single plane
Street/strip Car - Duel plane
Just for the record, I've seen plenty of guys with (traditional) small blocks making upwards of 550+ HP with duel planes normally aspirated. Even more (obviously) with a power adder.
Choice is yours. I know I'm going with the GMPP duel plane. My car afterall, is going to spend more time out on the street then it will at the track.
Hope this helps.
