air leak somewhere...
. So I then pulled off the passenger side valve cover, because there was more oil on the passenger side of the block, and I noticed that the back left corner looked like it had some oil on it, so I bought a new gasket, and replaced that. I also redid my header gaskets at the same time, because I had a big header leak as well,
hehe. Well after doing that, i've only driven the car a few times, and it doesn't seem like its leaking oil
so far.Well, with all of that out of the way, and I also just wanted to share all the damn work I did this last week
, I have an air leak somewhere. It sounds like a hiss coming from center of the dash, like on the back of the intake manifold. I already checked all the vacuum lines, and made sure the egr was bolted down ( I wanted to remove the egr / air system at the same time i pulled the manifold off, but didn't have any blockoff plates, nor the time to wait for them to come in, and it would throw a code since I'm a 97) So where could this leak be coming from. Its extremely quiet at first, then gets really loud as its about to shift, then gets quiet again. It might have been doing this before all this work, but my header leak was so loud, would have drowned it out . So what could be causing this? Anything I could have overlooked? I keep thinking it has something to do with the EGR solenoid, because I only think it does it at slight throttle, and it sounds like its coming from that area.Thanks.
-Seth
