weight reduction
Old Jan 18, 2005 | 10:33 PM
Abdullah's Avatar
Default weight reduction
my friend has a 94 A4 Z28 and he wants to remove some weight from his Z. what he shall remove so that he removes at least 200 to 300 pounds? Joe Overton are you there?
Old Jan 18, 2005 | 10:48 PM
FIREHAWK #07's Avatar
jack, spare, rear seats, sway bar, my buddy took off the foam underneath the nose(bumper) of his Formula, get an aftermarket hood, AC compressor & accesories, get all suspension parts that are tubular (LCA, K member, etc...) ..... whatever you dont need you can get rid of....
Old Jan 19, 2005 | 12:07 PM
regorih383's Avatar
ya everything he said, but keep in mind when you take that much weight of an LT1 you realy make it look crapy, and if its a daily driver i hope you think that what you are doing is worth it because when you start taking a/c and power steering it becomes a bad car to drive
Old Jan 19, 2005 | 12:21 PM
OutlawZ's Avatar
200-300 lbs is quite a bit of weight for something he might drive everyday. My car is still full interior and we're looking to have it down to about 3100lbs or so with me in it..... I've taken out all the HVAC stuff under the dash, passenger side and drivers airbag are gone (wheel is aftermarket now), tubular k-member, upper/lower ca's, drag brakes from Aerospace components up front, QA1's, no front bumper support or swaybar, lightweight seats, fiberglass hood.... Manual brake booster and manual steering rack as well as removed wipers and wiper motor..... I'm thinking all of these parts all added up should be close to 300lbs less overall if not more...... I think k-member, control arms, qa1's and lightweight brakes is over 130lbs....
I know the box with all my old crap weighs a TON..... But I don't drive my car everyday either... it's very streetable just a lot louder than when it was stock and i only drive it in good weather.....
Old Jan 19, 2005 | 01:21 PM
Mikey 97Z M6's Avatar
What's up Abdulah? Haven't seen you post around for a long time...
THE DIFINITIVE WEIGHT REDUCTION LIST FOR 4TH GEN FBODY'S
https://ls1tech.com/forums/drag-racing-tech/17319-weight-reduction-list.html
You're welcome....
Later man,
Mike
Old Jan 20, 2005 | 10:37 AM
Abdullah's Avatar
Hello Mikey! how are you? i sold my LT1 A4 Z28 to my friend and bought a 2000 LS1 Z28, soon it will be faster than my previous 94 Z28 . are you married now?.
