LT4 rev limit?
I`m sure Mobil 1 helps and the ATI damper.
How long it will survive these bursts,
I don`t know.Rev at your own risk!
With the stock valve train I would go about 6,400. I just puller up two stock LT4 files and this is what the Limit was set at
Now I can also tell you the Corvette tach seems to be WAY off on the to end
The computer stops giving fuel at 7,300 no matter what you set it at
Good luck!
upgraded lifters helps too
Good luck!
