opti again??!
Old Jan 31, 2005 | 07:33 PM
Aries's Avatar
Default opti again??!
well, my 396 LT1 is acting up again.
we had it running fine on Saturday, but revved it up hard one time under load and it backfired really hard at 5300 and the car shut off. Now it woln't start. No spark to the cylinders... Any ideas on a cause?
Old Jan 31, 2005 | 08:23 PM
96blackz28's Avatar
id say its the damn opti. EXACT same thing happened to me when mine went out. Revved it up to about 5k and POP, then it just slowly died and wouldnt restart. Man was i pissed. Sorry about your luck man, opti's are a curse!
Old Jan 31, 2005 | 08:52 PM
Aries's Avatar
I think I'm going to do the delteq coil pack conversion to fix this. Damn, that opti only had 40 miles on it too!
Old Feb 1, 2005 | 11:42 AM
moehorsepower's Avatar
Default Opti
Just remember the coil packs DO NOT eliminate the Opti completely, It still relys on the Hi and Lo resolution of the opti,A friend of mine went this route and still had failures due to the resolution failer of the opti. I had numerious problems with the opticrap and finally went to the dynaspark, Never had an issue since.............
Old Feb 1, 2005 | 08:50 PM
Ed Wright's Avatar
9-Second Club
We have had a couple of Optisparks fail here on the dyno. The screws holding the rotor in place came loose. I tell people to never just take one out of the box & bolt it on, the rotor screws are almost never tight. I use red locktight on those. Have never had one fail. What are you guys usually seeing fail?
Ed
Old Feb 1, 2005 | 09:07 PM
Default Opti
Mine was consistently shooting the pickup off the rotor through the opti like an arrow at 6500 RPM. I checked the pin length off the cam and it was good. I even pulled it out and put a little JB to make sure it was not walking in and out but still no luck. With the Dyna Spark everything has been ok so far..
Old Feb 2, 2005 | 01:25 AM
97LT1's Avatar
Double check your coil if you have an ignition box. I still had spark but it was not enough for the opti.(would still shock the hell out of your friends)(probably the juice from the ignition box still making its way through) I wound up replacing the opti not knowing this and then still had the problem. Only to find out it was the coil. If you have a stock one sitting around test it in place of the other. 40 miles sounds fishy for the opti to be going out already, unless you got water in it from something.
I think your problem might be something like I had.
Old Feb 2, 2005 | 10:56 AM
00Z-28-LT1's Avatar
i would say check the coil first and if its not that get the dyna spark.....i hate ignition problems....good luck
Old Feb 2, 2005 | 06:20 PM
Aries's Avatar
well, the coil is brand new (40 miles along with the opti, and control module) the MSD was not hooked up when this happened.
I'm leaning towards a problem with the rotor. Ed might be right on this one, I didn't check it and tighten everything before bolting it on... I'm also going to check the cam dowel with a micrometer to be sure of the length.
Old Feb 3, 2005 | 03:25 AM
TurboTA93's Avatar
its def. the opti.
Old Feb 3, 2005 | 11:37 PM
sc300's Avatar
thats what you get for trying to put a motor in a 240 that doesnt belong there...
sup chris..im just ******* with you...just following your threads to get you to hurry up and get your **** running so you can get spank by a real 240...see you around bud!!!
duy
Old Feb 4, 2005 | 01:33 AM
GhostZ's Avatar
One big vote for Delteq here....love mine and haven't had any problems at all. Very smooth throughout the RPM's.
Old Feb 4, 2005 | 12:02 PM
Black LT1's Avatar
most common problems do acure coz of the Opti....
I'm afraid the only thing I have in mind is to buy any second-hand opti and try the run again! and see if it happens again.
Old Feb 4, 2005 | 05:47 PM
Aries's Avatar
ok, fixed it today. Car is running great again!
Bolts holding the rotor on inside the opti backed out (Thanks Ed Wright for the suggested problem) and the rotor cracked in half. New rotor, New Cap, and new wires just for good measure. It Lives!
And Duy, as soon as I get a new tune on this thing (tonight or tomarrow) I'll be game for running your "Real" 240.
Old Feb 4, 2005 | 06:47 PM
Ed Wright's Avatar
9-Second Club
Glad you fixed it. I think ACDelco must have a four old girl installing those rotors. I always use a thread locker on the screws.
Take care, Ed
Old Feb 4, 2005 | 07:01 PM
97LT1's Avatar
Take care, Ed
It seems like that.
Old Feb 5, 2005 | 02:15 AM
blazin's Avatar
I Have a new opti coming. What locktite did you use? Do you Just have to pull the cap off and the screws are visable?
Old Feb 5, 2005 | 08:48 AM
Ed Wright's Avatar
9-Second Club
Just take the cap off, and there are two screws holding the rotor on. I have never seen them come out of the box tight. Very small screws, so be careful. I use red locktite for everything. I've been shifting mine @ 7200 all year long, runs about that at the finish line, and it sees that in the water box way too often. Has been fine so far.
Good luck, Ed
