LS1/LS6 lifters in LT1??
Old Feb 14, 2005 | 10:29 PM
GR8RIDE_96's Avatar
Default LS1/LS6 lifters in LT1??
are LS1 & LS6 lifters the same? also, would LS6, or even LS1 lifters be an upgrade when putting in a cc306?
Old Feb 14, 2005 | 10:52 PM
TwoFast4Lv's Avatar
same lifter as a LT1
Old Feb 14, 2005 | 11:07 PM
GR8RIDE_96's Avatar
really? huh, well thanks 'cause that i did not know.
Old Feb 15, 2005 | 04:56 PM
crow2's Avatar
LS1~LS6 LIFTERS ARE THE SAME!! LTI / L98 ARE DIFFERENT! THE BODY'S ARE THE DEPTH ECT.YOU ARE TALKING TWO DIFERENT LIFTERS!
Old Feb 15, 2005 | 09:05 PM
TwoFast4Lv's Avatar
Not according to the old Part numbers(circa 1998) We have been using them back and forth for a while. I know you sell tons of them so I must be wrong but just what we found years ago.
Does Comp sell a different one for LS1 cars now?
Old Feb 15, 2005 | 09:22 PM
disco192's Avatar
Lifters are one of the VERY few parts inside the motor that is interchangable between LS/LT motors
Old Feb 15, 2005 | 10:30 PM
atljar's Avatar
Ditto. I know both the lt1 and ls1 guys use the comp R (875-16) lifters. So if the aftermarket stuff is interchangeable, then why wouldnt the stock stuff be.
Old Feb 15, 2005 | 11:52 PM
GR8RIDE_96's Avatar
you see, that's what i thought, that the LT lifters are different from the LS ones, but they are interchangable. so that's why i was wondering if the LS lifters are better than the LT lifters to use for a higher revving cam. also, i hear the comp r's(875-16) are a b*#ch to set, is this true?
Old Feb 15, 2005 | 11:57 PM
atljar's Avatar
The comp Rs are a little more touchy, but i wouldnt consider it a b*itch. You want to set the preload from like 1/16th to 1/8th a turn and that should get you really close.
Old Feb 16, 2005 | 12:54 AM
97M6Formula's Avatar
LT1/LS1/LS6 all the same buddy I promise
Old Feb 16, 2005 | 12:55 AM
GR8RIDE_96's Avatar
great, thanks for your help
Old Feb 16, 2005 | 10:56 AM
crow2's Avatar
The LT1 lifters from GM are different ~the (plunger)-cup is .075" deeper than a GM LS1 lifter,and the travel between the two (Gm) are also different.At which if using one or the other would directly affect the pushrod lenght!
Old Feb 16, 2005 | 11:22 PM
then why do they have the same part number?
Old Feb 17, 2005 | 11:48 AM
crow2's Avatar
Actually they do not! (GM)
Old Feb 17, 2005 | 12:51 PM
At all of the sponsors here and summit the comp rs for both car are the same number...I dont doubt that you're right at all IM just saying alot of guys have been interchanging em without problems
Old Feb 17, 2005 | 04:46 PM
crow2's Avatar
I appreciate that,I have emailed my contact at COMP CAMS to see or too even learn how it is thier lifter will work in 1987 to present LS1.I am just confused with the fact that THE GENERAL is so much different.I also heard a long time ago that these lifters were the same?Any~probly beating a dead horse on this!
Old Feb 17, 2005 | 05:12 PM
Yea Im with ya on that barryI think companies are just confused however I wonder if the comp lifters are made for the lt1 specs or ls1sI assume lt1 because they state for standard chevy smallblock on summit
Old Feb 17, 2005 | 09:40 PM
Snow Dog's Avatar
im wondering if its the spring rate inside the lifter. maybe it takes more pressure for the early style to push the plunger down. aftermarket could easily change that rate to something they feel is better and at the same time be suited for both engines. just a thought. im curious to know the correct answer to this as well
Old Mar 2, 2005 | 12:39 PM
crow2's Avatar
Well this subject can go on and on.I finally got to speak with MARK CAMPBELL @CRANE CAMS regarding this issue.hopefully I can relate this to who may care!The important dimesions on a lifer are the diameter of the lifter body and the position of the oiling band around the lifter body.Our bitch was how can a LT1 lifter be used in a LS1 application.Because the plunger and cup depth is different between the GM lifters.Now there are aftermarket people who have a lifter that works for LT1'S AND LS1'S through 99 yr!Aftermarket lifters such as the CRANE'S lifters will only work ok to about .610 lift.Recommended preload is .060-.080"! Incidently,GM and some other manufacturers run thier preload at .060-.100" on hydralic lifters.My last response was that the GM lifter (LT1)THE CUP,plunger is .075 deeper than the LS1 lifter.TRUE!This difference in pushrod seat position would necessitate ethier longer pushrods or adjustable rockers.YES~our findings state that a aftermarket lifter such as CRANE or COMP CAMS will work with the proper pushrod lenght and cam lift-base circle diameters.OH WELL!
Old Mar 2, 2005 | 09:05 PM
Snow Dog's Avatar
just one of those things i guess. thatsnk for letting us know what you found out. personally unless two parts have the same part number im not gonna use it for an application that the manufacturer doesnt say its for.
