Does anyone know how to adjust 1.6 RR???
Thanks
Thanks
1. Engine Off.
You can either rotate the engine to find TDC, or rotate the motor until both the valves open and then close. Adjust the RR to your preference. I like 1/2 turn past lash.
2. Engine running.
Get them close, then start the car. Back each one off until it clatters, you will know it, and then tighten back up until clattering goes away and turn 1/2 turn or what ever you desire.
Lash is when you can move the push rod up and down.
The easiest way to find it is twisting and wiggle it back and forth.
You will be able to twist it still at 0 lash, but the push rod wont have a loose feeling to it.
Once you feel it for the the first time you will know what I am talking about.
Check this site out and scroll way down to rocker arm adjustment.
With roller rockers, it's tooooo easy.
1) ensure the set screw is out far enough that it won't hit the stud on each rocker.
2) ensure motor is on TDC (#1 piston) [if timing cover is off, the timing marks willl be at 12 o'clock on both gears, if not, you must rotate engine until intake valve opens, then closes and piston reaches TDC on that stroke]
3) you are now ready to adjust exhaust rockers on cyls 1,3,4,8...intake 1,2,5,7.
With RR's run the nut down to finger tight ( not tight, just where the the nut stops, wiggle the rocker a little then snug lightly), then rotate an additional 3/4 turn w/ wrench and lock set screw without allowing the nut to turn.
4) rotate engine 360*. Now adjust exh valves 2,5,6,7...int, 3,4,6,8 in the manner above.
The reason RR's are easy is the nut is not a ball and locknut like stamped steel rockers that have tension and is kinda hard to get the "zero lash" feeling.
Hope this helps.
I don't know, maybe my 25+ yrs, and my dad's 50+ yrs of engines and building SBC's is wrong, but I have never had an issue with 3/4 turn on Hyd lifters, that's why I never have to do a running adjustment.
Hope this helps.
thats a good web site
