CC 306 questions....
I think you'd be happier with something more mild, like a hotcam or similar profile. If you don't want a higher stall, it's going to be finicky driving a lumpy-cammed car with an auto. Plus, I think there are better cams for stock heads.
maybe if you want a different sound, you should investigate different exhaust setups? Just a thought.
but without doing alot of work, and spending alot of money, i'd suggest the following cams:
-LT4 Hotcam
-comp extreme 224/230 112 lsa
both are great cams and not overly crazy. just my .02
I think this is a great cam even with stock heads, though I would highly recommend getting a higher stall TC. Mine is only 2800 stall so it isn't bad at all on the street. My time and power are in sig. Also if you go with any cam that is going to have a lot of lift, you SHOULD redo the whole valvetrain to make it stronger and lighter so you can spin it higher.
I'm not saying it won't make a bunch of power, I'm just saying that for most people's daily driver cars there are better choices- let me clarify: Seat of the pants, a different cam (with more conservative duration) will be more friendly with things like low rpm acceleration. Even wide open, the 306 leaves something to be desired under the curve...
Sound clip:
http://www.auburn.edu/~doddjom/carrev.wmv
All I have left to do is tune my idle(it is as rich as bill gates) and I should be getting around 280-300miles per tank (currently getting 260, but I have to sit in traffic a lot and I have a lead foot
) All I have left to do is tune my idle(it is as rich as bill gates) and I should be getting around 280-300miles per tank (currently getting 260, but I have to sit in traffic a lot and I have a lead foot
.. i dont know how or why... and i am not an aggresive driver.. car rarely goes above 2K rpms ... and its got 2.23 gears?.. wtf... uhh... help?1) Check for leaks
2) Get on a wideband O2 sensor to see what your air/fuel ratio is.
