Install LT4 hot cam kit in a 94 Z
Have a few questions. THis is a buddies car and I'm not 100% familiar with the LT1's (i have 2 LS1's)
1. Do we have to change the rocker studs?
2. Is there an easy way to eliminate the a/c comp? the way the belt routing was it didnt look like it. Or is there possibly a idler pully kit to replace the comp. like the stangs have?
3. How should the car run, its an A4 will have 4.10's and a 3500 stall. has some other minor bolt ons and a catback.
Thanks for the help.
Josh
Josh
Hey Josh.
You dont have to change the studs unless he wants to upgrade the rockers to 7/16's for a little added stability. The rockers that come in the hotcam kit fit the stock studs.
There is a AC delete pulley out there althought I dont know much about it. Im sure others will chime in that know more about that.
With a mail order tune, he should be just fine. He has almost the same mods as me and with a smaller cam like the hotcam, it should be very streetable.
Hope this helps you out man. Talk to you later.
Originally Posted by QuickSilver
Bo has seen my car run he should be able to give and ide of how it runs.
Josh
Josh
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
EDIT--A/C delete pulley - GM pn 10115875. Expect to pay no more than $50 after shipping.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
thanks for the kind words Bo. You should make the drive north and come hang out sometime. I got a place for you to crash and there are some nice *** tracks here.
Josh
Josh
