new opti in.. now i have idle problems
#41
i finished installing my brand new optispark last wednesday and it ran perfect all of wednesday! even ran best 1/8 mile track times ever.. then thursday it wouldnt start. i realized that the ground wires on the coil bolts had fallen off so i reattached it and it turned over but ran like a dog.. feels like when you are off by a tooth on the optispark (94) is it possible for the opti gear to be in correctly but then fall out of timing? sorry if this isnt clear
#43
i mean just the little toothed thing that goes from the opti to the timing chain.. could it have been torqued enough to jump a tooth or something?
#47
the gear on the opti is keyed so you can only put it in one way. you cant get it wrong unless you bang it in, and you wouldn't run right from the start. sounds like you've got a different problem.
#48
well the first time i put this opti in i banged it in and it ran like crap from the starup... i took everything off, put the gear drive in right and reinstalled everything and the car ran like a champ for 24 hrs then it crapped out again
#49
Yeah opti's really suck, mine 2nd one went to crap after a year and half, car ran like poop, like it had a upgraded cam only it was the stock cam. OOOOO bad bad memories car was misfiring like crazy. New opti in and car ran like a champ. Good luck with it!
Greenfire
Greenfire
#51
im still having trouble with my car running like its on 7 cylinders... right now its in pieces and im going to be replacing the optispark again because i have a spare on.. my question is how do i test for arcing in either the coil wire or spark plug wires and how do i test for impedance? i have a multimeter but i have no idea how to use it lol
#52
Easy ways to test for arcing are letting the car run at night in the darkest area and looking for sparks jumping to something...or you can spray a light mist of water of the wires then use a test light and run it near the wires (don't pierce them) and see if it lights.
