Heads and Cam is in!!!!
Old Mar 28, 2005 | 10:27 PM
1QwickLT1's Avatar
Default Heads and Cam is in!!!!
...Well, after 22 hours I finally got my GM847 Cam and Ported and polished heads put in (2.00/1.55). I haven't really gotten into it but the SOTP is bad *** just hitting it alittle It was such a bitch to put everything in, but it definatly paid off. I still need a tune, and its got some surge down low, but other than that everything is tight. It sounds so mean at idle This is the biggest mod i have done to date (only 18) Once it gets tuned, and i get some nittos, i am hoping for low 12's/high 11's. Once I get a bigger intank fuel pump, and bigger injectors (if i need them) I am gonna run a 150 shot (hopefully 10's) and then im gonna need a rear ....If it even makes it that long LOL. Anyway, i just had to let u guys know how it went, i had been asking alot about it and figured i would let everyone know how it turned out. Thanks to all those who helped, Dave.
Old Mar 28, 2005 | 10:37 PM
Formula69's Avatar
congrats! cant wait to see how the tune does for you! this will be my next mod and im hoping for similar numbers.... what were the major problems you ran accross while doing this? did you have the block out of the engine bay or did you keep it in? and helpful hints?
Old Mar 28, 2005 | 10:48 PM
Vendetta's Avatar
Great stuff man, let us know what you end up running.
Make a vid
Old Mar 29, 2005 | 01:18 PM
1QwickLT1's Avatar
THanks guys, well, a few problems we had were the fuel lines (the tool we had had everysize but one to fit mine so we had to use a little plastic peice from a cap to undo it (ghetto i know but it worked ) Another thing when we did the piston to valve clearence test the intake valve (2.00) hit the outside of the dish (the little slot on top of the piston) BARELY so we had to dremel the little dishes on the piston (intake side). That was the main things....I didn't have any egr because i took it all out when i did the longtubes, so im sure that probally helped alot not having all that crap in there. Also the block was left in the bay. Good luck when u get yours done, u will love it. I still smile about it everytime i drive it LOL and i have already gotten a TON of complements of how it sounds
Old Mar 29, 2005 | 01:20 PM
1QwickLT1's Avatar
Make a vid
I dont have a camera, but some kid i goto school with did a sound record on his phone, and believe it or not, it came out real good. Is there anyway i can take what he has on his phone and put it on the computer as a mp3 or something? If so, i will borrow his phone asap
Old Mar 29, 2005 | 01:24 PM
97LT1's Avatar
How much did you have to clearance for the piston dish? I thought you didnt have to do this with that cam.
Old Mar 30, 2005 | 08:09 AM
IllusionalTA's Avatar
Probably had his head's milled when they were ported..
Old Mar 30, 2005 | 12:38 PM
Ken95Z28's Avatar
I have my blocked zero decked and heads milled and running a big lift cam in mine and still had clearance. .160 to be exact.
Old Mar 30, 2005 | 01:10 PM
1QwickLT1's Avatar
Yeah they were milled. The GM847 cam with 1.6 RR has like 595 lift...and that is a pretty big lift...
Old Mar 30, 2005 | 01:12 PM
1QwickLT1's Avatar
well we didn't have enough time to disassemble the block, so we mad a stencel of how big it should have been, and then taped the whole top of the block, and just cut out the intake side of the dish using the stencel.
