LT1 Dyno Archive
Old Nov 17, 2015 | 12:54 PM
  #521
smb72's Avatar
Default 1997 Camaro LT1
Home rebuilt LT1, stock bottom, CC503 with 1.6RR, ported heads done by myself, stock fuel system, Pacesetter LT headers with y-pipe and Magnaflow cats, SLP LM1, 52mm BBK TB, Accel Optispark. Put down 340 & 345 hp with old tune from PCM4Less tune.
Old Jun 27, 2016 | 01:51 PM
  #522
CALL911's Avatar
This whole sticky thread would be better if it had a list attached to the first post so it could be viewed in an organized and simpler way.
Until then;
Fully forged 383
AFR 227 heads
SuperVic Jr intake
Turbo cam spec'd by Llyod
S484 turbo
Pump gas and meth injection
24#'s of boost
1,008 RWHP 987 RWTQ
Old Dec 12, 2016 | 03:08 PM
  #523
tbird31's Avatar
I don't think I ever posted up what mine made last go-round. Few changes were made when redoing valve springs and brought down the CR a bit from being higher then expected before. New exhaust setup, and some cooling mods will be going on in the next few weeks.
355ci - 11.8:1 CR
ported stock castings
hand ported intake
Holley 58mm TB
Lunati 231/239 .570/.585 110
1 3/4" headers/ORG/GMMG
T56 - 3.73s
!AC - EWP - UDP - LS1 lid
EFI 24x setup
Tuned by Alvin at PCM of NC.
422hp - 395tq
Old Mar 7, 2017 | 08:05 PM
  #524
6lbsoft's Avatar
97 SS M6, 383, Trick Flow 185cc, Comp 268HR, stock intake, stock TB, headers, full exhaust, CAI, 91 octane tune 336whp, 375wtq
Old May 9, 2017 | 01:30 AM
  #525
1970CSTLT1's Avatar
Had my 1994 Cheyenne dynoed at 296rwhp and 328wrtq with a stock 139,000 mile long block LT1/T56.
Mods include SLP airfoil, $30 eBay air intake elbow, Hedman 1 5/8 headers, dual 3in pipes, Flowmaster merge, 4in single Flowmaster Delta 10 muffler, CSR Summit electric water pump, 1LE a/c delete pulley, EGR delete, 15 ohm spark plug wires, new Optispark, and a 93octane tune but no dyno tune just yet.
Old Jul 13, 2017 | 05:49 PM
  #526
transbird95's Avatar
Just had mine tuned on tuesday at tpis. I have a 355 with forged pistons and h beam rods on the stock crank. LE 21* tfs heads and cam. 4000rpm stall and 4l60e. With a 9" rear end.
Car made 392 whp and was still pulling at 6700 but was having some ignition issues and had to stop. This was on a dynomite dyno.
Old Sep 10, 2017 | 04:12 PM
  #527
94TAand 05GTO's Avatar
1994 Trans Am GT, M6, 100% stock except for Moroso CAI & K&N air filter: SAE 267.7 HP @ 5100 RPM, 310.8 LB-FT @ 3200 RPM.
Since then I have installed a BBK 52cc throttle body, 1.6:1 Comp Cams roller rockers, a new optispark, and a new catalytic converter. I hope to get it dynoed this year before winter strikes.
Old Oct 9, 2017 | 11:18 PM
  #528
TwoFast4Lv's Avatar
basic 383 with TH400 and Nine Inch on 29.5s. More coming soon!
Old Oct 16, 2017 | 07:43 AM
  #529
The Batman's Avatar
basic 800hp 383 haha
what kind of goodies does it have?
Old Oct 16, 2017 | 07:45 AM
  #530
The Batman's Avatar
I would wait until you can get a set of headers and a Catback, egr delete if allowed, then dynotune it!
Old Oct 17, 2017 | 08:50 PM
  #531
TwoFast4Lv's Avatar
Basic 383 Brodix -18 headed LTx with a 300 shot. it made 53x N/A through a TH400 and 9in
If we had not burned the valve it should have went just over 900Whp. I hurt it the week before on "E" and this was trying to make the west coast shootout on C23.
new valves on the way pistons TBD
BTW That is at 6,600 It peaks at 7,700-7,900
Old Apr 23, 2018 | 10:53 PM
  #532
AdsoYo's Avatar
This was on a Mustang dyno on a perfect day. Sunny, 70, bone dry, at sea level.
Heads
Trick Flow 21*
215cc intake port
2.055/1.60 valves
54cc combustion chamber
11:1 compression
Cam
219/227 .549/.565 114+3
Intake
Fully ported and polished by LE
52mm throttle body
The Rest
mid length headers, single Random Technology cat, GMMG cat back
stock T56, Fidanza aluminum flywheel, Strange 12 bolt with 3.73 gears
390hp/380tq
Old Nov 30, 2018 | 12:14 PM
  #533
Doe'nStein's Avatar
Not my current set up, but before i had the engine rebuilt. Stock engine with CAI(filter, straight pipe, aluminum elbow, air foil, and coolant by pass mod) Hooker Super Competition headers. Stock 2 1/4 exhaust with the exception of the mufflers replaced with tiny glass packs. It also had 4.10 gears and a tune. It made 295 hp with an exhaust leak on the drivers side header flange. Can't wait to dyno the new set up.
Old Aug 20, 2020 | 03:01 PM
  #534
Horace Johnson's Avatar
Originally Posted by Rare96WS6
Stock 254rwhp/297rwtq ran 14.2@97
ported heads, LT4 hotcam, Ed Wright tuning 380rwhp/363rwtq
ran 12.5@111
A4 96' WS6
did you have long tube headers or stock manifolds?
Old Jun 2, 2021 | 07:59 PM
  #535
Rare96WS6's Avatar
With the stock numbers I posted, it was with stock manifolds. With the 380 number it was with AS7M/RK Sport mid length headers.
My best run with this set up was 11.9@112.
