LT1 Dyno Archive
Old Dec 27, 2008 | 06:29 PM
  #321
hot93rod's Avatar
365/361 As soon as engine was built. Seems kinda low compared to other numbers I've seen on here... Would a cat back, and intake help this to get me closer to the 390 range? Seems possible if that is my main bottlenecks right now.
completely stock ws6 intake (w/paper filter)
stock bottom end (balanced)
stock injectors, and tb
stock cat back w/lt jet hots, and ORY
mild cam (224/230 @.050)
full bolt ons (other than above)
valve job, ported heads, 11:1 comp ratio
rods, pistons, springs, valves, 1.5 rr's
Old Dec 29, 2008 | 06:59 PM
  #322
AChotrod's Avatar
get 1.6 rockers and longtube headers with true duals, or a nice 3" cat back with a cut out. in my .02
Old Dec 30, 2008 | 05:17 PM
  #323
hot93rod's Avatar
I already have the full length headers, and I am considering looking at the 1.6's, but the guy who built the engine gave me some reason why he didn't go w/the 1.6's when he did it... I just don't remember the reason he gave, it could use some more lift, but I don't think I'm going to bother w/that, I'd rather just do a cat back like you said, a cut out may not be a bad idea, I just think it'd be better to have it open all the time, lol.
Old Jan 2, 2009 | 10:05 PM
  #324
SS RRR's Avatar
Village Troll
My dyno graph rules.
Old Jan 4, 2009 | 09:05 AM
  #325
hot93rod's Avatar
LOL, so what blew up?
Old Jan 4, 2009 | 09:07 AM
  #326
hot93rod's Avatar
2 questions, I just saw some of your videos, and was wondering what cat-back do you have on your car, b/c it sounds quite nice. Second thing... does your car run a 13.6 w/that setup that you have now, or are those videos old? That just sounds like you're off by about 2.5 seconds??
Old Jan 6, 2009 | 02:11 PM
  #327
AChotrod's Avatar
LOL! The 13.6 was a while back I got the car to go 13.32 with just a cat back and DRs.
I havent been back to the tack with the new set up yet. Its winter !
Those vids are Lpp Lts ory and B&B triflow with a open cut out.
Thanks!!
Old Jan 9, 2009 | 11:39 AM
  #328
GrannySShifting's Avatar
Your an *** Brian
WHats a moderate cam only LT1 M6 dyno and a serious cam only deal dyno? Not funky faky numbers compared to what yours made on my dyno what do you think Brian?
Old Feb 1, 2009 | 07:43 AM
  #329
SSweet97's Avatar
Corrected yesterday from 333 RWHP 315 RWTQ to 340 RWHP 335 RWTQ.
Stock bottom end GM Performance Parts LT4 conversion kit. Running a little lean, but I'm getting it dyno tuned in two weeks.
Old Feb 6, 2009 | 12:56 PM
  #330
nichols92's Avatar
Originally Posted by speed_demon24
Just my daily driver. Stock 105K mile bottom end, unported intake, stock mechanical waterpump, and Ai 200cc h/c package. Opti had a lose rotor that wasn't helping either.
No way not to the tire. Probably not at the crank either. I would be really mad if thats the case.
my motor:
383 LT1
Callis crank
compstar rods
mahle pistons
TEA TrickFlow heads
Ported Edelbrock LT4 intake
58MM polished TB
Made 449HP to the tire through a 12 bolt moser, 3rd gen camaro on a Andy Wicks E85 tune. There is some more power in it but I have a feeling something is "wrong"
Old Feb 13, 2009 | 11:52 PM
  #331
buckner163's Avatar
Stock other than 4:10 gears LT4 with 55k miles made 301 rwhp 305rwtrq. Ran a best 1/4 of 13.009 at 106. Best 1/8th was 8.29 at 83mph.
Added hotcam/homemade catback and KN filter it made 330rwhp 327rwtrq untuned and ran 8.0s in the 1/8th at 87mph and best 1/4 was 12.89 at 111mph.
Added longtube headers and PCM4less mailorder. Ran 12.30s at 115mph and best 1/8th so far has been 7.89 at 90mph. No dyno numbers with the headers/tune yet.
Old Feb 21, 2009 | 07:50 PM
  #332
1_bad94Camaro's Avatar
borla cat back, mac mids, bolt ons.
305 RWHP with 327 FPT
13.007@107 2.2 60'
Old Feb 25, 2009 | 08:51 PM
  #333
97knightrider's Avatar
stock switched to synth stripped interior and drag radials 13.4 100mph auto
Old Feb 28, 2009 | 08:36 AM
  #334
Ihasfip's Avatar
7.9 @ 97 in the 8th. Badly slipping clutch, bald nittos. Cut a blazing 2.49 60 ft. That was on an 80 shot of sauce. Now has 150 shot , 4.10s, a clutch, and ignition. I will take it back to the track after I get the dana 60. No 1/4 mile times or dyno runs yet.
D
Old Mar 7, 2009 | 11:38 PM
  #335
blk97z28's Avatar
My numbers SUCK
1997 camaro z28 A4 with 2:73's and 74,310
245/270
then headers and y-pipe only
265/293
Have not dynoed since TB bypass and CAI
What are your gusses for my new numbers??
Devin
Old Mar 21, 2009 | 08:59 AM
  #336
creepingdeath94's Avatar
I have a copy of a LT1 Formula 2 staged sprayed that runs on my local dyno running 676/63? I have a copy of the run. Apparently, every run, he sprays so hard that the head lifts ever so slightly off the block and leaves a little coolant puddle under the car after the run. Not sure how long that can keep going on for before something gives, but apparently it has been doing every time for a while now. Maybe he goes in there and replaces head bolts every run, I don't know, but the sheet/run is pretty impressive looking.
*forgot to mention, this car is a daily driver and he drives it to and from the local college.
Old Mar 21, 2009 | 04:29 PM
  #337
slick1851's Avatar
Originally Posted by blk97z28
My numbers SUCK
245/270
265/293
Devin
Get a tune on your car, it could be the reason why your not up to par on power.
Old Mar 21, 2009 | 04:31 PM
  #338
slick1851's Avatar
He must be spraying that car very very hard, id like to see a dyno graph to see how long its making that power for and not just a spike.
I had two freinds with turbo cars, when they were on race gas pushing high boost every now and then the heads would lift.
Bottom ends never got hurt and both cars are still runing
That guy your talking about needs stronger head studs lol
Old Mar 21, 2009 | 07:38 PM
  #339
I would hope he already has the strongest studs he can get lol. Anyway, It is more than just a spike...you can clearly see where both stages kick in and it holds pretty good considering. It's like a drawing of a mountain or something :-p Anyway, I will definitely get the page scanned and posted here ASAP. I thought it was pretty cool being it is a daily driver total sleeper.
Here is the scan/copy:
*don't mind that piddly run below it...we were messing around comparing it to my run on my car that had a small fuel pump and was waaaay lean :-p
Last edited by creepingdeath94; Mar 22, 2009 at 11:17 AM. Reason: added picture/scan
Old Mar 23, 2009 | 03:33 PM
  #340
slick1851's Avatar
Yeah that sheet looks like a very fun setup when it hits!
Whats the rest of his setup?
