LT1 Dyno Archive
CC306, 11.8:1 comp., STOCK HEADS, type Rs, LTs, 3" duals w/ Xpipe, 1.6rrs, dyno tuned, 52mmtb, LE ported/welded intake, 42lb SVOs, etc.
Lookin for 425rwhp w/ LE ported Trickflows...then 450rwhp w/ custom grind...
289/315
that was before the exhaust and pullies. mods in sig. basically just a full bolt-on A4. no track times yet
the actual last one i had was 275/310 or something, with everything in the sig except the trans. and stall. dont really understand it but i wasnt there when they dyno'd it so i dont know if something went wrong. I had to run and get some stuff and they dyno'd w/o me
93 Firehawk with A4
K & N Air Filter
Aluminum Driveshaft
58mm BBK Throttle Body (w/ adapter to 52mm ports)
TB Bypass
Meziere Electric Water Pump
MADZ28 PCM
MAC 3" Y-Pipe and Catback
3" High-flow CAT
Edelbrock Coated Shorties
3:73 w/LSD
http://memimage.cardomain.net/member...51_13_full.jpg
stock LT1 bottom end w/82000 miles, 6 speed, LE2 head and cam, 1.6 RR's, guideplates, hooker LT's, no cats, GMMG, elec. wp.
***CAM WAS NOT DEGREED AT ALL DURING INSTALLATION***
that could mean up to a 15-20hp difference
depending on how far (and which way) it is off.
If you are spending that kind of money on a cam and time to install it,
spend an extra $30 and a few min on a degree kit.
Engine built by LME, installed/tuned by GForce, custom Wiseco pistons & Cam Motions grind, Jessell shaft mounts, LME max ported gutted & rebuilt AFR210 heads, long gorey list of engine components, KOOKS Stainless LT stepped race headers & stainless KOOKS Y-pipe, tranny built by T56 Rebuilds, custom driveshaft & Moser-12bolt, BMR Kmem/upper/lower A's, etc, etc.
GM Hot Cam Roller
58mm Twin Butterfly TB
1.6ratio Roller Rockers
Roller Lifters
331 inch lbs springs
MSD Cap and Rotor
MSD 8.8mm Wires
Denso Iridium Plugs
6 Speed M/T
4.56:1 Rear Gears
Hooker Comp Long Tube Headers
CSM Electric Water Pump
Ported Intake To Match TB
Port and Polish Heads and Intake to match
Stock Bore, Crank, Rods and Pistons
