LT1 Dyno Archive
I have since upped the boost to 21 psi, installed a 58 mm TB, raised the runners in the intake and ported for 58 mm, plugged a 1/4" boost leak, installed a custom Bell intercooler 2.5x the size of the Vortech unit, and destroked to an 8.5/1 363 cid (matches the turbo better). I haven't got the kinks worked out yet, but you can judge for yourself what it might make now.
We want video of pictures of that setup!
I could not find all my old files
here is the oldest. post Blower explosion
Stats: junk yard LT1 with LPE 211/219 cam and 1.52 rockers, SLP CAI and B&B Tri Flow
Same combo with a Comp Extreme cam 218/224
next came a SLP Duel Duel ,12 bolt ,CSI electri water pump ,Hooker LTs and a GM 847 cam...mainly because the CXE cam expired almost taking the engine with it. This came with a 14 hour reserection with the help of JimBob and Ryan K
Same Combo with a 75 Shot. This was good for a 8/10th drop in ET!
now this is the same combo on the same exact tune with a earily set of Lloyd Elliot heads. this was the old 11 second N/A combo
NOW to what we got the other day. These numbers as well as ALL the other numbers were UN-locked. they may change once I get to analize the file with WinPep 7
Now to many that may look ok but my goal is some thing more like Jim's dyno graph here. we are still tuning on this one as well
We will see what the future holds. We have never really tuned on the blue car. I am going to try a few new tuning ideas on it.
I hope this helps a few curious minds
Stock 95 Formula a4:14.3@97"2:73 car,Yuck!"2.360
Stock 99 LS1 m6:13.2@108 with 2.2 60
Type: 383 LT1 9.0:1
Block: LT1 4 stud main
Oiling: Melling HV Oil Pump, Canton 7 qt Road Race pan
Crankshaft: 4340 3.75" Eagle
Connecting Rods: 4340 5.7" Eagle
Pistons: SRP
Cylinder Heads: LT4 castings reworked by Lloyd Elliot/ 2.08/1.60 valves
Camshaft: 224 /236 .606/.628 with 1.6
Rocker Arms: Comp Cams Pro Mag 1.6
Intake Manifold: LT4 reworked by Lloyd Elliot
Induction: ATI Procharger P-1SC @ 8lbs
Ignition/Computer: Computer mail order tuned by Jeff Creech/ Mallory HY-Fire 685
Headers: Pacesetter LT's
Exhaust: Borla
Cooling System: Factory except for CSI EWP
Fuel System: Msd 50# injectors/ Racetronix plug and play system/ Aeromotive adj FPP/ AlkyControl Methanol kit
Drive train/Transmission-
Transmission: Stock MM6
Clutch/Converter: Mcleod Street Twin
Driveshaft: Stock
Rear Axle: Ford 9 inch/ 35 spline axles/Spool with 4.11 gears
Dyno in the sig
