Spec Clutch Break In Period
I put my stage 2 clutch and flywheel in today and I think I'm gonna like it! Smooth as butter, no chatter whatsoever and it actually engages/disengages at the top of the pedal instead of the bottom. I've read a few times that there is a break in period for spec clutches before you should get rough with it. Is this so and how long is the break in period??
Also, I compared the flywheels today and according to my bathroom scales LOL the spec billet flywheel weighs 5 lbs more than the stock one, I was hoping for lighter!!
500 miles is the norm. As far as the flywheels are concerned I wouldn't be a bit surprised if the spec is heavier for a few reasons....
1. your stock flywheel was probably resurfaced a few times....loss of material = loss of weight
2. the cast flywheel could be a little pourous, nothing you could see but def a little weight there
3. worn teeth on stock flywheel
etc etc
Billet is carved from a solid chunk of material so its def solid and new so 5lbs on a bathroom scale which could be 2-5 lbs actually isnt out of the question. If you wanted lighter...shoulda gone Fidanza...aluminum...mmmmm
etc etc
