airfoil problem, won't idle!
I enlarged the IAC slot on the airfoil quite a bit to get the numbers back down. Give it a try -- it shouldn't hurt anything. If all else fails, I would just leave the airfoil out of the equation...
[edit] For clarification, this is all assuming you have reset the computer or performed the 'IAC reset' procedure. Drive around for a while before you do any grinding.
I purchased my air foil from a random ebay seller too. If it still stalls it out give take the TB off and give the IAC passages a good cleaning.
Another thing to watch out for that I found on my Vette was, some idiot put a PCV valve in the passenger side valve cover where only an elbow should be, preventing the filtered air from the TB into the engine. Only ZR1 Vettes and other rare models have 2 PCV valves. There should be only one PCV.
