Check Out All These Mods
I wanna hear any suggestions you guys have. Other sthings I need or dont need. I've got about 12 grand to spend.
- SLP 4.10 gears
- Custom grind cam I cant remember exactly the specs. I think it was something around 242 duration 114 lobe and .576 lift
- Trick flow Heads Ported to match the lt4 intake. The guy said they would flow over 300 cfm
- Trick flow pushrods, pro form 1.6 roller rockers
- LT4 intake ported to match trickflow heads
- 396 stroker kit by Eagle, 4340 forged h-beam rods crankshafts and pistons
- Heavy duty Timing chain
- Jet Hot Headers & Y pipe
- Under & Over Drive Pulley Set
- Electric cut-out
- dual borla tips
- Not sure on which hood to get yet
- And I’m converting my 96 style to the 98-02 style, so I have purchased the front end rear and side fenders + the 2 side ground effects
- FUEL INJECTORS – here is a question I don’t know what Lb injectors to get????? Please let me know based on the info given
- fuel pressure regulator?????
- OBDI conversion w/tuning
- triple platinum spark plugs
- MSD 8.5mm Ignition Wires
- and also having my tranny rebuilt
- 58mm TB
- MAF
- Custom mats and carpet
- new console
- new ebony black leather seats
- B&M Ripper shifter
- Spec Stage 3 clutch kit
- BFGoodrich g-Force T/A KDW-2
- Blacked out zo6 rims 18x9.5 front 18x10.5 rear
Also will be Painting entire car not sure on the color
Who is going to get the Trick Flow's to flow over 300? If I remember right, AI was working a set of these when they came out and were going to be hard pressed to safely get over 300 out of them....more likely high 280's-mid 290's without coming close to working on the integrity of the head. If it's some Joe Schmoe who is going to port them, I wouldn't count on anything near 300. AI's first port of them netted around 250cfm.
Also $12K for what you are planning is going to be very iffy. Your stroker is going to cost you a lot more than you expect. Plan for a little over half of your budget and expect to spend more than that. Injectors....really depends on what you end up putting down to the ground. Cam....I'd wait to see the flow #'s before I get a custom grind....have the cam matched to your heads. I don't see why you would need an FPR.
If it were me in your position, I'd look to sell the LT1 and buy a used LS1. I'm sure you can find a 98 for around that and with the money you have left over and from selling the LT1, you can buy a budget Phamspeed kit and put down more than you'd ever see from a N/A 396.
Just my $.02
That's why I was asking, if it isn't a dry setup...why would bigger injectors be needed.
I dont really want to convert to LS1. And yes it is about 12 grand. I have all prices set and calculated. We will be doing most of the work including painting. Actuall it's more about 14 grand I have the items I will selll calculated in their.
I was leaning more on the 36lb but just wasnt sure. Thanks for the input.
Anything else?
Just my $.02
I'll look into the suspension.
thanks
If anyone can safely get 300 out of them, I would trust Lloyd to do it.
My heads just came back from Lloyd
Just little 210cc GM LT1 Castings
Flow is not alot....around 290ish .600 and up never dropping off at .700. should work with my baby cam and .640 lifti know Lloyd and Bret do work together on occation
Yea and the Annivarsary Yellow was #1 on my list. With black accents.
What kind of HorsePower should I be expecting. Or what do you guys think?
Because I was reading about the 36 lb injectors and they said thay were good up to 450 HP. I kind of figured that I would be over that and maybe thought I might need 42 lb????????????
Let me know
thanks
