Mass Air flow Sensor Ends?
{ Mass Air Flow Sensor Ends(MAF Ends) - $50 to ? - Replaces stock MAF ends and Maf screen with a ported set of MAF Ends that still utilize the original MAF Sensor.}
What will this do for the car & were do I get one?
I keep getting a code for my mass air put a new one on same thing do you guys
Think the new mass air flow sensor end will fix this.
The car is a 94 Impalla SS Thanks
Doubt it will do anything positive for you....some folks have seen a decrease when going with a ported or Z06 MAF. What code are you throwing? May want to try cleaning you MAF first to see if that fix's it.
And no, I don't think it will fix whatever code he may be throwing.
Alot of times it is the wires breaking that will give you codes. I have had to replace a few of the ends on my harness including the MAF, IAT, MAP, and both O2s and well as a few others. The MAF was hardest to diagnos If I remember correctly. It helped that I have 4-5 MAFs laying around from testing years ago.
As GhostZ said putting new MAF ends on won't help with your problem. Performance gains ,if any ,would only be relized with tuning
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
The code says mass air malfunction. That was with the old mass air so I but in a new mass air & it's giving me the same code. I used a snap on code reader & that what it said.
I don't know what eles to do any help would be great. Thanks.....
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
As GhostZ said putting new MAF ends on won't help with your problem. Performance gains ,if any ,would only be relized with tuning![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Not a clue....
Might want to check the wiring and conector ends. I would probe them between the PCM and the MAF. Moving the wires and connector around while doing this helps. In that scanner you are reading it is called a 'wiggle test'
Just a guess that might help
