Highest N/A LT1/4?
Joe Overton is running 9.3s N/A stock block LT1 but he's not on an LTX intake
My Dad and I are gonna try to make the number with an automatic and 23* heads, but not with a stock intake..tall order I know....but this is not the typical LT1 build either.
David
Basically what im saying is that the 23 degree heads just dont have the potential as a 18 degree, or 15 degree head for that matter. Valvetrain angle is far from optimal as are a bunch of other head/ flow characteristics of the 23 degree head. I think you will be hard pressed to make that sort of power out of a 23 degree head.
Overton's car, Ed Wright's car, ou812z/28 on this board's car are much more impressive, to me anyway. Overton's car runs in the 9's and the other two run low 10's at 3350lbs all motor. A friend of mine went 10.50's@3350lbs with stock casting LT1 heads and a stealth ram, the car had low 10's in it but he parted it out.
Ed Wrights car has LT4 heads and intake, that's Probably the quickest near factory car I know of and he is on the factory PCM.
My Dad and I have a set of 23* heads that flow like a set of 18* heads, they flow what Mingames did(according to him) and we have a better intake than he does, we make not make the number at the wheels he does because of the automatic, but will make the same at the flywheel that he does.
David
on another note...who makes 15 degree heads for sbc? that would be raw for an all out n/a motor.
I guess you could consider 18 or 15* heads exotic but I wouldn't consider them any more out of reach than a complete FI setup.
David
If I'm sounding like a dick I don't mean to be but I hear this argument all the time about my SB2 stuff. Now that I can see as being exotic but anything less is not imho.
GM 18*, and canted valve SB2.2...to me are exotic....you have to buy all the supporting members to make the stuff work, intake, rocker arms, pushrods along with having headers made.
Our heads are standard 23* small block chevy heads that are converted to fit an LT1. All standard small block chevy stuff will work with them including Hedman 1 7/8 headers, shaft rockers etc.
Now our intake may be considered exotic as it is the only one on the planet like it, but hey you gotta do some stuff different to go faster.
Seeing as Mingames 18* 383 LT1 is the only one I know of, there may be more, who knows....that in itself makes it exotic.
David
