Odd plug readings
Old May 23, 2005 | 09:05 PM
dhdenney's Avatar
Default Odd plug readings
Well some of you might recall my earlier posts about my high RPM miss. I haven't located the problem but fouled out my plugs in trying to do so. So I chnged them today. The front half of the motor (cylinders 1-4) are pretty normal looking. The back half (cylinders 5-8) are solid black. Injector pulsewidths are good. BLMs are 128. Plugs were NGK TR55's with a .035" gap. O2 voltages are similar and in decent range. It's not the Delteq cuz for example the 4 and 7 cylinders are on the same coil. Anyone seen this or can you at least point me in the right direction?
Old May 23, 2005 | 09:09 PM
FIREHAWK #07's Avatar
i know stock gap is at .050", but why gap them at .035" with TR55's? I see your using the Delteq, does that require you to gap them a lil smaller.... OR are you running the n2o on these plugs??? i would use a colder plug like the TR6 with n2o...
Old May 24, 2005 | 03:25 AM
dhdenney's Avatar
Well I myself didn't install the Delteq. I was at school (long story). So the guys that did it changed my plugs but instead of going back to TR6's (which I had), they put TR55's in (why I don't know). But there was no juice run on them. Since I've had juice, I've gapped my plugs tight however.
Old May 24, 2005 | 05:27 AM
SRZ's Avatar
SRZ
I've got the same thing w/ my TR55's and delteq. Think it's the plugs. Switching to TR6 next month and see what happens.
Old May 24, 2005 | 06:41 PM
dhdenney's Avatar
Hmm. So you have the same problem with cylinders 5-8 being black? I put in some cheap copper Champion plugs until I can figure out my upper rpm miss. Didn't wanna foul out $2.25+/ea NGKs when I can foul out Champions for $1.28/ea.
Old May 25, 2005 | 02:11 AM
SRZ's Avatar
SRZ
Yeah it's basically the same problem. At 1st I thought it was the alternator since it was dipping when I got up high in the rpm's. Changed it and still got the miss. Pulled the plugs and the 4 up front are burning great but the back 4 are close to being fouled. I'm not sequential either but batch fire so it's really a mystery to me.
Old May 25, 2005 | 10:48 AM
dhdenney's Avatar
That's really odd. Do you have the same high rpm miss I have? Above 5000 it just breaks down. I've reached the conclusion it's the opti giving the Delteq a bad signal.
Old May 25, 2005 | 10:51 AM
HBHRacing's Avatar
do you have a converter still? If it's getting cloged it can put pressure on the rear cylinders and cause them to miss and foul.
Old May 25, 2005 | 01:57 PM
dhdenney's Avatar
Naw, I cut it off 4 days after I got the car, lol. That was over 4 years ago.
