1/4 mile mph??
What rear ratio do you have? 2.73 or 3.23? I am assuming a 2.73 which would make sense. My Vette has a 2.59 in it. When it does the 2-3 shift down the 1/4, it drops out of its power band and pulls like a slug.
CAI
Free Mods (tb bypass. CAT delete (not gotted) MAF de screen)
Air foil
Throttle Body (52mm with a built in air foil)
1.6 roller rocker upgrade with springs
Full tune up (fluids, plugs, wires, etc etc a good running car is a fast one)
Electric waterpump
Under drive pullies (you may get 1 peak hp, but your under the curve numbers are great)
Coil up grade (MSD, or Crane)
Ignition box
Headers
Cat back exhuast, maybe a cutout
Suspenion
Gearing
PCM knock modual
Tuning
If you did everything, I am real surprised at the MPH, thats waaaaaay low, even for the 60 foot. Even if I spin bad, I still get a decent mph, crappy et but decent MPH.
I would put a fuel pressure guage and check the pressure, maybe a compression test, get datamaster and scan your pcm. It may be knock retarding. or running waaaaay lean.
But get it scanned, and get some data on the car. A Laptop, AKM cable, and Datamaster will sort most things out in a jiffy.
TB bypass
LPE CAI
Random Tech cat back
Madz28.com tune
160* Thermostat
My best run was a 13.893@100.31 MPH, and that was with a cracked transmission, no tune up, no headers
Now I wanna bring it to the track with my LT's and tune up and hopefully run a 13.4-5.
My car also seems to not pull so hard in 3rd as it does in 1st and 2nd.
