EGR Delete
also, same thing w/ AIR is anyone has that info also!
thanks
The part numbers are 74203L and 74203S. Both I believe are unfortunately for fords. I looked at the EGR valve gasket and these part number are more symmetrical than the gasket. Sorry but this wouldn’t help. Looks like your back to making your own again. Just go to some place like Lowe’s and get a piece of aluminum. Get a new gasket and trace just the outside edges of the gasket and it mounting holes onto the metal. Cut it, grind it, do what ever you can with the tools you have to make it the same shape as the gasket and then drill the holes. A dermal could help a lot. Again sorry about the part numbers no working out.
As far as any sensors and trouble codes I have heard that it will and it will not cause the check engine light to come on. Anybody have more input on that? I would think that it probably would and I don’t know how to prevent that.
