header bolts
Old Jun 11, 2005 | 03:52 PM
FlamingChicken's Avatar
Question header bolts
Well if getting the old manifolds out and getting the long tubes in the slot werent bad enough, when i went to bolt the header on the damn bolts dont clear the tubes!!! Im having problems with two bolts on each header. I bought Kooks 1 3/4 LTs and they didnt come with new header bolts so i assume you reuse the stockers. Is this true? If not where can I get some new header bolts thatll fit. Let me know if you need any other information. Any help or ideas would be greatly appreciated.
Car is a 95 formula if that matters.
Old Jun 11, 2005 | 04:55 PM
Smokinlt1's Avatar
I got mine at Autozone for around $20 but then again I'm using shorties
Old Jun 12, 2005 | 02:08 AM
Fade2blk500's Avatar
the autozone bolts should work fine, if not i'm sure you can find some at www.summitracing.com or something.
Old Jun 12, 2005 | 02:31 AM
FIREHAWK #07's Avatar
DO NOT use the stock bolts!!!!!! You can get some from Autozone, O'Reileys, or local speed shop.... that is alll!!!!
Old Jun 12, 2005 | 08:47 PM
ExtinctBird's Avatar
I used ARP 3/4" long stainless hex head bolts from my local parts store. They have nice compact 3/8" heads that cleared my Pacesetter 1-3/4" primaries fine. Good luck.
Old Jun 13, 2005 | 08:57 AM
matt94z's Avatar
Get some ARP 12 points, I love mine.
Old Jun 13, 2005 | 10:29 AM
00Z-28-LT1's Avatar
i vote arp 12 point or 6 if that is better for you....i believe thunder sells arp
