Heads/Cam for forged 383
Old Jun 12, 2005 | 12:45 PM
1 last 1's Avatar
Default Heads/Cam for forged 383
I'm looking into what kinds of heads/cam to go with a completely forged 383 lt4 setup. I have heard some good things about lloyd elliots stuff, does anyone have his website address. I was also thinking about going with AFR LT4 210cc. Any suggestions. Also planning on spraying a 200 shot of the juice. Keep in mind this will be a street car as well. Thanks in advance.
Cody '95 Trans AM- couple of things
Old Jun 12, 2005 | 01:22 PM
Jordan57's Avatar
Well....I think a LE setup will run out of breathe on the spray. As in you won't gain as much as you should because you will need some serious heads to flow what you need for that type of shot. My vote would be to buy some AFR 215 raised runner heads bare and send them to Lloyd Elliot or TEA, AI, or someone like that. Have them fully ported and stuffed with bigger valves and have a custom grind by any of them. This would work best for your setup and comfortably put you at 600rwhp+ on the gas.
Old Jun 12, 2005 | 03:47 PM
WhiteSSP's Avatar
I've heard that Ai has gotten 300cfm out of Trick flow heads. But I'm not positive.
Old Jun 12, 2005 | 04:32 PM
flyinZ's Avatar
Id give Joe Overton a call...he'll set you up right. If you need his #, PM me.
Old Jun 12, 2005 | 04:39 PM
Jordan57's Avatar
AI (brett) did get 300 out of the twisted wedge castings. Joe O is the man, however I had heard he got out of the business of porting, besides his own stuff??? I don't for sure know that though.
Old Jun 12, 2005 | 04:49 PM
flyinZ's Avatar
Ah, Joe doesn't do the porting, just customizing cams,etc...Eric Bradbury does his porting...You can go to Joe's site, and it'll give you more info, pricing,etc..
Old Jun 12, 2005 | 05:05 PM
LittleRedZ's Avatar
Old Jun 12, 2005 | 05:34 PM
Black97's Avatar
these are exact what I have just done !!! My engine will be ready after 1 or 2 weeks.. Its (Lunati Crank,Oliver rods,Diamond pistons) a 383cid with a top notch quality forged.. 210cc AFR Competiton Heads.. And 200 wet nitrous shot (TNT).. I also want drivability.. What a coincidence!!! My trans was A4 ,but I swap it T56..
Old Jun 12, 2005 | 05:39 PM
LittleRedZ's Avatar
sorry to tell you this but if you plan on drag racing bad idea, t56 wont hold for long with anykind of 600rwhp +
Old Jun 12, 2005 | 05:42 PM
Black97's Avatar
Viper T56
BTW: I will drive on street not drag.. I mean my car will be "highly modified street car" ,not a drag car.. The real reason of the swapping is my camshaft 237/245 584/579 113lsa and with A4 trans it will be not funny to drive in traffic..
Old Jun 12, 2005 | 05:49 PM
LittleRedZ's Avatar
Viper T56
just dont be surprized if you destroy it on the street.
Old Jun 12, 2005 | 05:51 PM
Black97's Avatar
I wanted to go with G-Force's T56, you know they are strongest T56 ,but I tought its too much for my application.. http://www.g-forcetransmissions.com/tran_gt-56.asp
Old Jun 12, 2005 | 06:33 PM
97blkz's Avatar
Viper T56
similar to my cam and no problem with streetabilty. Now my tranny is another issue!
Old Jun 12, 2005 | 06:37 PM
Black97's Avatar
I'm glad to read this!
Old Jun 12, 2005 | 06:47 PM
Smokinlt1's Avatar
Lloyd site is www.eportworks.com, check out his LE3 setup, plus it's hard to beat his prices
Old Jun 12, 2005 | 08:11 PM
Quickshotkimber's Avatar
Eric ported my stock castings. He is da man. He also ports Joe's stuff along with everything else that you can think of. My heads flow under 250 cfm, I guess my ETs speak for themselves though. BTW, it was cheaper that almost everyone out there
Old Jun 12, 2005 | 11:14 PM
1 last 1's Avatar
thanks for all of the replies,any other info will be much appreciated, ill keep everyone posted on what i decide.
cody
'95 TA
Old Jun 13, 2005 | 08:47 PM
97M6Formula's Avatar
similar to my cam too but my wiring is fed up so I dunno yet
