LT1s with braided lines in their engine bay?
Tris
Braided line needs to be custom made. It is not that difficult as long as you have the correct tools and I prefer Earls line & Fittings (They are soooo much easier to get on). You can get them all at Jegs or Summit. You will need a hacksaw, electrical/duct tape, a vice with aluminum jaws works awesome (also get from Jegs), and plenty of bandaids for your fingertips when the metal stands stick you (hurts like hell). You also can use the aluminum wrenches Jegs sells but regular wrenches will work if you are careful.
What are you running in place of your opti? Man that's a nice bay, you have any more pics? Your block looks like it sits further back but I know that's because of the radiator. Any reason for doing it the way you did? Man I thought my stuff was together you guys are putting a hurting on me! LOL!
Nice job on the bay.
The reason why it looks so different is cause I removed almost every single thing that could be and I redid all the wiring from headlight to tailight and ran it through the framerails instead of the engine bay. I smoothed all the holes and even filled the heater core hole instead of just putting a plate over it. I put the radiator sraight up/down cause I kinda wanted to show off the polished radiator and it actually improved cooling (never above 130 degrees on the freeway) and never ever above 200 anywhere.
I did it this way to do something different than anyone else out there is doing. I read alot of street rod magazines and went to Goodguys and NSRA shows to get ideas. I gave up on going fast with the LT1. I am happy with the 12.2 @ 120 that I did with a 75 shot. I know it had more cause my 60' was 2.2. Yes, that is a stock motor time, I have no clue what I did to get that MPH. That time was run 2 years ago before I cleaned it up and got new rims and some misc other stuff. Should be a tad faster now if I put the 75 shot back on.
I am doing the bolt on thing right now and finding ways to loose the weight and be different is high on my list.
We will be going 7.9s with just weight reduction and cooler air, sig tells the story!
If it is a stock motor, why all the fuel cell and all that?
Still have A/C or is that a trans cooler set up on the front with the hard lines?
Thanks for the openess!
No AC. That is a large oil cooler with the big lines going in it and a tranny cooler behind it with the small lines in it. You can't see the tranny cooler to well.
