Custom LT1 Alternator Relocation Bracket...anyone interested?
Old Jun 24, 2005 | 01:02 AM
93turboLT1's Avatar
Default Custom LT1 Alternator Relocation Bracket...anyone interested?
just thought I'd post a few pics of the bracket I made to relocate your alternator down low so you can use tall valve covers....my buddy did the same and wow does tall covers and no alternator make our motor look SO much better...let me know if your interested or what you think...I could do some work for you.
I'll post some photo of the trans am we just finished.
Attached Thumbnails Custom LT1 Alternator Relocation Bracket...anyone interested?-dsc00889.jpg   Custom LT1 Alternator Relocation Bracket...anyone interested?-dsc00892.jpg   Custom LT1 Alternator Relocation Bracket...anyone interested?-dsc00890.jpg
Old Jun 24, 2005 | 08:19 AM
outdooricon's Avatar
I assume you're talking about that little piece that is connecting to the bottom part of the alternator in the pics... what belt would this need (there's no ac on that car, right)?
Old Jun 24, 2005 | 08:58 AM
Shon Herron's Avatar
Why not make a set up that does not retain the factory bracket?
Will begin working on that myself and let you know how it goes....got one car already locally that is running it that way, still has PS, but no A/C...........
Old Jun 24, 2005 | 10:46 AM
Brett95z's Avatar
If someone could make up a bracket that relocated the alternator low, maybe passenger side, and still retained the ac. And no pulley where the alternator went. Id pay half decent money for one.
Edit: Is that a peice of an oil pan side rail ( the peice that bolts up to the oil pan ) that is holding the bottom of the alternator on
Old Jun 24, 2005 | 11:55 AM
The set up I mentioned earler put the alt where the A/C compressor was but had to go to a 3rd gen alternator b/c the size of the 4th gen is too big.
I really think it would be possible to run it on the driver side low if you can keep the rotation going correctly and get enough belt travel. Some of the problem is probably the belt tensionor. I would like to see that removed or displaced to another location.
To locate the alt on the other car mentioned he used hiem joints (rod ends) to get this done, like March does on some of their kits.
Maybe I can come up with something over the summer....
Old Jun 24, 2005 | 04:09 PM
Brett95z's Avatar
Ya, i have seen that setup. I want to retain my a/c. I Think it would be possible to do on the passenger side. Make a mount that bolts to where the air pump mounted. I have tons of room on that side with that trash out of the way.
Old Jun 26, 2005 | 11:15 AM
99.9percenter's Avatar
Looks good! I want it!!
Old Jun 26, 2005 | 06:47 PM
monster7's Avatar
if you just want an alt get a more performance or some other people
i have a more performance it fit the car good
im worried that it wont fit in my truck when i go to drop it in there i think it may hit the frame so im lookin at other mounts also
here is a pic of the more perfomance mount
Old Jun 27, 2005 | 09:48 AM
The Big Show's Avatar
This looks like the version that Jon Addis built a couple years ago...
Old Jul 5, 2005 | 11:12 PM
93turboLT1's Avatar
yeah I saw I few pictures but didn't like a few things he had to do....my buddy bought the original, and it doesn't fit worth crap....so i'm glad I tryed it myself....
Old Jul 6, 2005 | 01:24 AM
SRZ's Avatar
SRZ
Yeah, Jon just cut a hole basically and it didn't hold up under load. They cracked as soon as you got on it. W/ the bracket in this one it may do better. I bought the other version Jon made that went to the driver side and haven't had a problem since and that was almost 2 yrs ago.
Old Jul 6, 2005 | 07:18 AM
1970judge's Avatar
id like to see something bypassing a/c and ps..
Old Jul 6, 2005 | 07:50 AM
SRZ's Avatar
SRZ
Go to MadMan Racing. He's got that.
Old Jul 6, 2005 | 08:06 AM
SJM has that.
Old Jul 6, 2005 | 12:33 PM
monster7's Avatar
so do i look above at my post
Old Jul 6, 2005 | 12:37 PM
Watch out, the mods might get mad about that type of stuff....for some reason they dont like it.....(ask me how I know...)
Old Jul 7, 2005 | 06:53 AM
Funkybird's Avatar
I'm interested, you have a message 93turboLT1.
Old Mar 10, 2009 | 07:59 PM
Shelbe1991's Avatar
Question Custom Brackets
Does anyone know of any custom accessory brackets for an LT1 going into a 1992 GMC 1500 series truck??
Old Mar 10, 2009 | 08:11 PM
Formula350's Avatar
Holy necromancy!
I suppose since you mentioned "custom" that me recommending you using the ones that came off the truck is out of the question?
Why not just run stock GEN I stuff since there's tons of aftermarket bracketry? All you have to make sure about is the crank hub stuff so it lines up with the rest.
Old Mar 10, 2009 | 09:50 PM
Black94Z28's Avatar
I have that, just running a belt between the alt and crank pulley. No ps or air
