would not running an alternator cause ign. problems?
Old Jun 27, 2005 | 08:13 AM
z28boysteve's Avatar
Default would not running an alternator cause ign. problems?
Well basically Ive got these misfires past 5,500 that get really bad past 6,000..
Its positively NOT valve float, its gotta be ignition, and I was thinking I have no alternator or belt driven stuff.... would this affect the ignition even if I run an Optima Red top and charge for 1 hour at 200amps between passes?
Old Jun 27, 2005 | 09:40 AM
HBHRacing's Avatar
yes, It can also cause fuel issues. Even if your running 12.5 Volts (which is the best you will probably get out of a fresh charge) Thats not enough ESPECIALY at high RPM where the load on the coil and fuel pump is high.
Old Jun 27, 2005 | 09:52 AM
where can I buy a NICE alternator relocation kit that puts it on lower drivers side, and includes belt?
Old Jun 27, 2005 | 10:00 AM
WhtLT1's Avatar
https://ls1tech.com/forums/lt1-lt4-modifications/341606-custom-lt1-alternator-relocation-bracket-anyone-interested.html
Old Jun 27, 2005 | 04:29 PM
I was looking for a more attractive, lightweight piece like the one I found here. http://www.sjmmanufacturing.com/cam_eng_lt1.html#
