oil temp. 2 high! need help!!!
Old Jul 3, 2005 | 10:24 AM
94'BLKBRD's Avatar
Default oil temp. 2 high! need help!!!
When i drive my car 2 my gf's house which is 25 miles from my house my oil temp. jumps from 160 to 270 in about 10 minutes.when im going about 80-90mph on the freeway and when im slowing down because of traffic or because im going to exit the freeway and i let go of the gas to where the car is going about 40mph I hear the exhaust backfire and a small popping noise and that's when the Service Engine Soon light comes on.this happens every time i go 2 my gf's house,and my car has started to run hotter .I took it to a mechanic and he just recommended a oil cooler.DOES ANYBODY KNOW WHAT COULD BE CAUSING THE OIL TEMP. TO GET HOT SO QUICK????
Old Jul 3, 2005 | 10:35 AM
Fade2blk500's Avatar
Is the car having any overheating problems? Perhaps an oil cooler would be a good investment.
Old Jul 3, 2005 | 10:51 AM
94'BLKBRD's Avatar
My Car Is Running Hotter, Before It Ran At 180-190 Now It Runs At 210-230 But That's Not 2 Hot But Im Concerned About The Oil Temp. Which Is Causing My > Service Engine Soon Light< 2 Come On
Old Jul 3, 2005 | 11:24 AM
Snow Dog's Avatar
where did you put the sender for the oil temp gauge? what code is being thrown? that will help out to know this info.
Old Jul 3, 2005 | 11:27 AM
94'BLKBRD's Avatar
I bought the car with the gauge installed and I haven't got the car scanned for the trouble code
Old Jul 3, 2005 | 11:28 AM
94'BLKBRD's Avatar
What oil cooler would you guys recommend??
Old Jul 3, 2005 | 11:41 AM
Snow Dog's Avatar
you need to figure out why its getting hot. a cooler is only a bandaid. these cars dont need them to run correctly. the oil should only be getting that hot under heavy and prolonged abuse such as road racing. your car may already have a cooler on it also. does the oil filter screw directly into the block or does it screw onto this black thing that has two rubber hoses running to it? it will be in the same location either way.
i would find out what code you are throwing first. also make sure your oil level is up where it should be. adding an oil cooler should only happen after you figure out why it runs weird. if it was running lower but is now running higher theres a problem that needs to be fixed first. and for a street car i would not recommend an aftermarket cooler. you dont need it and you do need the oil to get hot so as to burn off the contaimanents in the oil. oil temps of 210-230 are perfectly normal.
Old Jul 3, 2005 | 12:22 PM
94'BLKBRD's Avatar
I meant 210-230 for the water temp.
The oil temp. is 260 or higher
Old Jul 5, 2005 | 10:31 AM
94'BLKBRD's Avatar
Can a partially burned spark plug wire be causing this??Because i found one of my spark plug wires laying on the headers and when i zipp tied it with the others it was burned.
Old Jul 5, 2005 | 07:20 PM
Snow Dog's Avatar
no that would just cause missfires on the engine. does the engine still run well?
Old Jul 5, 2005 | 08:17 PM
94'BLKBRD's Avatar
Engine Runs Perfect Except For The High Oil Temps. Im Going To The A Pontiac Dealer Tomorrow Morning To Get My Car Scanned For The Trouble Codes.so Hopefully I Will Have The Trouble Codes Posted Tomorrow.
