optispark replacement
Old Jun 30, 2005 | 11:10 PM
tx3's Avatar
tx3
Default optispark replacement
quick kinda noob question but my optispark is pretty much blown on my friends 94 z28. so if he got an msd ignition kit instead of a new optispark distributor would that replace it?
Old Jun 30, 2005 | 11:11 PM
tx3's Avatar
tx3
also to add which msd ignition would i need, if you can post a link to one thatd be great.
Old Jun 30, 2005 | 11:14 PM
dhdenney's Avatar
I think the most common problem with the optis is the cap and rotor being bad so MSD does make a cap and rotor kit but it's unclear as to whether or not he purchased that. This could be what you are talking about:
http://www.msdignition.com/2005/2005_9.htm
Old Jun 30, 2005 | 11:15 PM
tx3's Avatar
tx3
i heard you can just get a whole ignition kit instead of the whole optispark set up. like a digital ignition kit
Old Jul 1, 2005 | 06:57 AM
00Z-28-LT1's Avatar
you have to keep the opti because of the optical sensor in it, you can do a coil per conversion but they are kinda pricey and dont always give the best results. if you dont have a radical motor then i say your best bet would be to just put a new opti on or if you have alot of money to spend you can get a daynatech opti. make sure you dont have any oil leaks from the timing chain cover when you replace it as well, that can ruin a opti.
Old Jul 2, 2005 | 08:12 AM
RUNanLt1's Avatar
Is there any possible way to check the opti without it being on the car. Wouldnt think there is but hey i figured id post it. Would suck to put the car back together then find out the opti **** on me. Between the waterpump and the timing something possibly could have gotten on it.
Old Jul 2, 2005 | 07:22 PM
jninan2k2's Avatar
i dont think so....just have to put it on and hope for the best...hell if the opti is old enough you might as well go ahead and replace it while your car is tore down
Old Jul 3, 2005 | 09:38 AM
RUNanLt1's Avatar
expensive
Old Jul 3, 2005 | 10:23 AM
Fade2blk500's Avatar
Go ahead and put it together. It isn't much work to put an opti on at all. Couple hours max, unless a waterpump bolt breaks off then your just f'd in the butt
Old Jul 5, 2005 | 08:34 PM
jninan2k2's Avatar
this is very true
