Compression readings too low?
Old Jul 9, 2005 | 04:44 PM
dhdenney's Avatar
Default Compression readings too low?
I ran a compression test today on cyls 3, 5, and 7. I had been wondering about those back cyls so I tested 3 cuz I was pretty sure it would give a good reading. Back ones were a little lower. According to the pamphlet, as long as all cyls were within 25% of each other it was acceptable. But what about a high performance motor? See what some of you guys think.
3= 170 psi
5= 138 psi (19% variance of 3)
7= 150 psi (12% variance of 3)
Common or should I be concerned?
Old Jul 9, 2005 | 05:01 PM
z28boysteve's Avatar
You sure you gave the engine enough cranks, you should crank for at least 5 seconds, and make sure it holds the pressure and doesnt bleed off.
Old Jul 9, 2005 | 11:34 PM
dhdenney's Avatar
Right, I gave her plenty of cranks. I may try it again some time and get my dad to watch the gauge and maybe it will tell more of a story.
