ported heads and intake
As far as gains, it depends on who does them. I would recomend calling Lloyd
EPortWorks
When looking at HP ratings you need to think for a second as to how the test was done people see the 425hp number thrown around with the whole LT4 HOT package, that is on the dyno with a dyno tune headers minimal acessories etc, test the STOCK engine in the same manner and you should top 360hp. With the LT4 HOT package you mi9ght get 350hp to the wheels on a near freakishly good car where the cheaper LE1 will put down more.
Ignorance is the primary reason for the popularity of the LT4 stuff.
LE3 is $1850 then you have to add rockers($250) to get it to the same level of parts as the LT4 HOT package, this does put it at a similar price but it will deliver as much at the rear wheels as the LT4 kit can HOPE to at the flywheel. If you want to buy LT4 heads then have them ported and get another cam and springs, sure maybe you can make more power yet but the cost of the porting will add to make that setup a lot more expensive and you are going to have a hard time making a 350 use that airflow. If someone needs to buy head then they can consider used cores or LT4s but they should not delude themselves into believing the LT4 stuff is so great.
Frankly I think you proved my point about it's popularity being due to ignorance when you tried to amke the LE kits out as costing the same amount.
The LE1 even makes more power than the LT4 HOT kit and with roller rockers would on be $1350, if you know where to get the LT4 heads assembled and with the HOT kit for that amount of money I suggest you buy all you can and start selling them for $1800 you will make a killing.
When looking at LEs site consider those are rear wheel numbers and the 425hp for the LT4HOT is flywheel and optomistic, the 370rwhp as the lowend for the LE1 is more than 425fwhp unless you have a freakishy efficient drivetrain because you would be talking only 12-13% lose.
If someone wants a seriuos stroker then LT4s or aftermarket are good choices till that stage there are better options.
