GM847 with afr 190cc
Old Jul 20, 2005 | 09:31 PM
Juicedz's Avatar
Default GM847 with afr 190cc
I currently have a 226/226,.554/.554 cam with these heads. I have up graded my springs to handle a .600 lift. i also have forged pistons, rods etcI'm spraying a 200 shot through an NX dp kit. I have a th400 and the stall is 4000. Will this came work well with my heads and my combo in general?
Old Jul 20, 2005 | 11:29 PM
DocT's Avatar
sounds smokin'
Old Jul 21, 2005 | 09:05 AM
Juicedz's Avatar
ttt.....
Old Jul 21, 2005 | 10:15 AM
Ultra Z's Avatar
is the block splayed? forged rods h beams?
Those heads are not great unless ported heavily, mine were worked slightly but still needs improvement.
Old Jul 21, 2005 | 10:59 AM
RealQuick's Avatar
I would tink the 847 cam would work nice...
Old Jul 21, 2005 | 11:13 AM
Juicedz's Avatar
the rods are eagle hp with bronze bushings
Old Jul 21, 2005 | 11:14 AM
Juicedz's Avatar
I believe that the heads stock flow about 270 @ .550
Old Jul 21, 2005 | 11:16 AM
Black97's Avatar
what the lsa of the cam??
Old Jul 21, 2005 | 11:18 AM
Ultra Z's Avatar
my flowed 282@500 with a pipe. That was a basic port with a 5 angle valve job. So no so impressive. Afr numbers are way over rated
Juicedz's Avatar
The current cam is 112, but what are my options with the gm847? 114 or 110?
Old Jul 21, 2005 | 11:19 AM
Ultra Z's Avatar
its a 112
Old Jul 21, 2005 | 11:24 AM
Black97's Avatar
for a 200 shot of nitrous I think you shouldn't get tighter than 112 lsa..
Old Jul 21, 2005 | 11:43 AM
Juicedz's Avatar
what lsa would you recomend black97? also do you think that the gm847 is too much for a 358lt1?
Old Jul 21, 2005 | 12:39 PM
Black97's Avatar
no it isn't too much but you should also work on heads.. I would go with 113-114 lsa cam if I will use 200 shot nitrous..
Old Jul 21, 2005 | 01:18 PM
BigKap94z's Avatar
I think those heads are fine as is. Sure they are not super impressive, but they are much better than than stock heads. There have been plenty of people that have made 350-360RWHP with stock heads and that cam. There will be much to gain with head work tho. I think you would be fine, and the 112 LSA should be fine for the spray too. I say it sounds like a good combination. Should run great.
