what times do you see me running?
Old Jul 22, 2005 | 12:12 PM
ele-blue95's Avatar
Default what times do you see me running?
My best time has been a 12.97 @ 109.35 with a 2.104 60'' on street tires. still running stock 10 bolt with 3.42s.
_________________________________
95 z28 (t-56)
355 with lt4 hotcam, stock heads, 1.6RR,mac-headers, cai, ele-water pump,52mm tb, 32 pound inj.,tune by ion at madz28, control arms,lowering springs, KYB aj.shocks,pan hard rod, 17x9.5 front,17x11 rear ZR1s.
Dyno numbers 346 rwhp 350 rwtq
Old Jul 22, 2005 | 12:33 PM
HBHRacing's Avatar
What do you mean? Have you done something different since that best time or are you asking what you would run under perfect conditions and a better launch?
Old Jul 22, 2005 | 12:40 PM
Camaro 0wner's Avatar
Possibly a 12.7 with a 1.9 60'. Shouldn't be too hard with the 3:42 gear...
Old Jul 22, 2005 | 12:43 PM
BlackScreaminMachine's Avatar
Internet Mechanic
That combo seems about right or the time. Given that you can knock the 60foot down you will gain 3-4 tenths in the 1/4 and maybe 1-2 tenths in the mph but again maybe its the weather your running. Best times often come in the cold weather with decent track prep. One thing hurting you is no cyl head work. Opening up those ports may give you more top end.
Old Jul 22, 2005 | 12:44 PM
Internet Mechanic
but again, i just noticed its a m6 so you may not be consistant, or that you really cant get on the car too hard with out spinage. So work on the launch
Old Jul 22, 2005 | 03:47 PM
94stanger's Avatar
mid 12s with a good 60'...
Old Jul 22, 2005 | 04:02 PM
Vendetta's Avatar
00.000@000.00mph if you don't get off your computer chair
Old Jul 23, 2005 | 03:52 AM
2MuchNos93LT1's Avatar
take your front sway bar off.
Old Jul 23, 2005 | 09:41 AM
Siphon's Avatar
is there something that I don't know? This isn't the first time I've saw someone say "take off your front sway bar". What would that do besides drop a few pounds?
Old Jul 23, 2005 | 10:49 AM
Greenfire's Avatar
My hubby has taken his off of the SS, it does reduce weight on the frount end, just like re-locating the battery to the trunk. Mine is still on but not bolted up, so the car defintley doesn't corner like it use too. The less weight on the frount the better you want your rear end to plant itself on launching.
blue95 - Like I have been trying to tell you, get that rear end beefed up and slap some drag radials on it and you be slapping 12.70's in the face! Good launch and good tires, you can't lose. Well maybe the rear end, but hurry up with that 9-inch and let her rip!
Course, ya know blue you might get away with 12.70's on your stock rear end like Clint has been doing, WITH drag radials on the car.
Old Jul 23, 2005 | 11:48 AM
HBHRacing's Avatar
removing the front sway bar allows the body to lift transfering weight to the rear to push it down giving you more traction. With the front bar removed and only a cheep TQ arm I am cutting 1.9 60 foots on STREET tires that way.
EDIT: remember people. The general rule is for every .1 you cut from your 60 foot you go about .15 faster in the 1/4. if you go from a 2.1 to a 1.7 your going to drop close to if not more then .5 off.
Old Jul 23, 2005 | 10:28 PM
ele-blue95's Avatar
Thanks everyone. that was in 95 degree weather. and i have a shift light with 6000rpm pill. I know i need tires. about to put a 9'' in the car, i've broke one 10 bolt already. about to put some ported heads on the car. hoping for low 12's high 11's on a 1.6, 1.7 launch.
