Blew up the rear, what to do??
Old Jul 23, 2005 | 12:32 AM
The LT1 That Could's Avatar
Default Blew up the rear, what to do??
I plan on upgrading the differential to the clutchless style, i guess the zexel torsen?? but i was wondering if anyone makes upgraded 10 bolt axles. I really dont wanna spend the money on a 12 bolt or 9", when I wont be throwing down that much power to the ground anytime in the near future. i have a 3 channel abs rear btw, so if i go 12 bolt or 9", i wont have ABS correct?? does it have to be tuned for this, or does the ABS INOP light just stay on??
suggestions anyone??
Old Jul 23, 2005 | 12:42 AM
HBHRacing's Avatar
you can retain ABS with a 12 bolt.
New diff $400
axles $300
gear set $200
Install set $100
stud Girdle$140
Misc fluid ect $50
average install $350
And what do you get? The same week 7.65" ring gear and a big dent in your bank account.
Tack on another few hundred and you can get a 12 bolt and install it yourself and never have to worry about it again.
Old Jul 23, 2005 | 12:46 AM
very good point.
The only thing is I am getting the posi used for about $100, with labor going to be around 200 or so.
Still sound like a bad idea?
Old Jul 23, 2005 | 12:49 AM
Brett95z's Avatar
Just think of it as borrowed time. It will do the trick for now, but dont expect it to last.
Old Jul 23, 2005 | 01:17 AM
what about running a 8.8" rear end. not sure what to pay for it, so someone give me suggestions on an acceptable price for one. the shop doing the work has an 8.8 ready to fit in an f-body.
Old Jul 23, 2005 | 02:29 AM
NXSLT1's Avatar
Do what I'm in the process of doing.......9".
Old Jul 23, 2005 | 02:57 AM
wish i could afford it. gonna see what all is wrong with it first, and go from there, if its just a jacked up posi, i will swap in that used zexel torsen, and be done with it. otherwise, may just add some moser axles and go with a 3.73 gear set.
Old Jul 23, 2005 | 03:25 AM
Vendetta's Avatar
An Ford 8.8" will run you about the same price of a 12-bolt, not worth it at all.
Old Jul 23, 2005 | 06:12 AM
BlackScreaminMachine's Avatar
Internet Mechanic
8.8 is marginally better in stock form but yes when they are both built up its around the same price.
Old Jul 23, 2005 | 09:29 AM
HBHRacing's Avatar
no matter what you do. You could spend 10 grand on a 10 bolt. But you still have the same problem. The 7.65" ring gear. It's the week point and there is NOTHING you can do about it.
Old Jul 23, 2005 | 02:55 PM
thanks everyone for your input. car wont be in the shop till next week, so i got some time to figure out what i wanna do. again, thanks everyone!
Old Jul 23, 2005 | 03:00 PM
Vendetta's Avatar
Not a problem man. Good luck with the bitch, keep us posted!
