11.4 Compression
Old Jul 30, 2005 | 04:08 PM
rhaig's Avatar
Default 11.4 Compression
Is 11.4 compression going to be a little high for a pump gas car? What do ya'll think about copper head gaskets?
What do you think of this parts combo...
396 all forged, 11.4 compression
Trick Flow 195cc heads ported to flow 285cfm
GM 847 cam
Ported intake, by me
36lb injectors
think they match up well?
Old Jul 30, 2005 | 04:52 PM
Ari G's Avatar
i have 12:1 in cp on 95 oct,I know of may people that have 13,1:1 in CP on 93 oct dayly drivers and they are just fine
Old Jul 30, 2005 | 05:54 PM
monster7's Avatar
i have 11.3
runs pump gas all day long
although its on the engine stand right now
Old Jul 30, 2005 | 05:58 PM
MattIROC's Avatar
11:5:1 compression in a 383 motor, I run 93 octane to the track, then I mix 93 with 112. No problems here!
Old Jul 31, 2005 | 03:03 AM
97M6Formula's Avatar
Ditto... When its done
Old Jul 31, 2005 | 04:22 AM
JasonShort's Avatar
Moderator
I ran 12.2:1 compression on my 396 everyday in 100 degree weather on 93 pump gas with no problems ever.
Jason
Old Jul 31, 2005 | 11:03 AM
z28boysteve's Avatar
11.45:1 pump gas always, even at the track, unless im gonna juice, when I do use the sray, ill be running race gas.
Old Jul 31, 2005 | 11:27 AM
rhaig's Avatar
Sounds great 11.4 it is! How bout the parts being right for each other that i have listed..
Old Jul 31, 2005 | 12:34 PM
Its all in the tune....You have to just find the sweet spot with most timing and cr possible with 93... Depends on your dynamic compression ratio too.. But you should be fine
