94 Z28 Shifting Problems
Old Aug 3, 2005 | 08:08 PM
C-wylie's Avatar
Default 94 Z28 Shifting Problems
The car won't shift into 2nd Gear during WOT. Auto Transmission
Been dieing more then usuall.
While driving normal cruising speeds in 2nd or 3rd gear it will sometimes drop down a gear and then back up again with no input to the throttle?\
I'm floor'd to why this is happening?
Anyone have any ideas?!?
Stock Car also.
Old Aug 3, 2005 | 08:21 PM
bugg1's Avatar
My buddy had the same problem in the same year car. He had it rebuilt and it was still doing it. He sent it back to the shop where the work was done they said it was something in the PCM or so ****. 1 week later problem solved.
Probably doesn't help much.
Old Aug 3, 2005 | 09:13 PM
C-wylie's Avatar
Thanks any info will help,
Anyone else have any ideas?
Anything I can check to figure out what it might be?
Old Aug 3, 2005 | 11:58 PM
5w20's Avatar
burned clutch packs?
Old Aug 4, 2005 | 10:54 AM
C-wylie's Avatar
How expensive would that be to fix?
Old Aug 4, 2005 | 11:40 AM
FlamingChicken's Avatar
youd have to rebuild it or at least disassemble the tranny to replace clutch packs. easy way to tell if that is it is to drain fluid and look for friction material. checking your fluid should be one of the first things to diagnose tranny problems. good luck to you.
Old Aug 4, 2005 | 08:01 PM
slowmofo's Avatar
mine was doing the same thing at one time, mine ended up being the band. Now I just have that damn stall wall problem
Old Aug 4, 2005 | 09:26 PM
Carbed4thGen's Avatar
I'd say some PCM or at least an electrical problem
Old Aug 5, 2005 | 01:57 AM
C-wylie's Avatar
Sweet, thanks guys.
If it was in the PCM, would I just have to replace it?
How much do those cost? Not cheap im sure
Old Aug 5, 2005 | 09:00 AM
I believe your just going to have to start testing stuff. Get a manual, or if you can get onto a program like Mitchel on demand or something
