dies at idle
Old Aug 11, 2005 | 10:26 AM
ls1charged's Avatar
Default dies at idle
i have a 93 z28 and when i start it up and leave it in park it idle's fine but if put it into drive and let it sit there the rpm's will go up and down and then if i let it sit there for like a minute or so at a red light it will die on me and im kinda of thinking its because its not getting enough gas for some reason, the car runs perfectly fine when your driving it but when your stopped it wants to die on me, so i was wondering if u guys had any opinion's on what it could be and or something that has gone bad that i should replace so let me know what u guys think.
Old Aug 12, 2005 | 01:50 PM
ls1charged's Avatar
i guess knowbody knows
Old Aug 13, 2005 | 02:27 AM
LT1 Guy's Avatar
If it's not getting enough gas, you could look into getting a new set of injectors. Check your fuel filter too. Or just have your injectors cleaned.
If it doesn't turn out to be fuel-related, then I'm thinking it's something wrong with the ignition... and that's a whole other ball game...
Old Aug 13, 2005 | 10:09 AM
ls1charged's Avatar
lets hope it has to do with fuel, i really dont want to have to mess with the ignition. thanks for your input.
Old Aug 13, 2005 | 11:23 AM
MrBill97396's Avatar
if you have high mileage on the stock injectors they will crap out on you.
Old Aug 15, 2005 | 01:54 PM
ls1charged's Avatar
i would be so releived if it is just the injectors.
Old Aug 15, 2005 | 01:56 PM
ls1charged's Avatar
does anybody know what the 93 z's had for stock injectors?
Old Aug 16, 2005 | 03:13 AM
GEARHED's Avatar
22#, check the sticky at the top of the page as its listed there.
Could also be the opti depending on the mileage. If all else fails (checking fuel delivery) have it checked. Its classic symptoms of them failing.
Old Aug 16, 2005 | 06:50 AM
ls1charged's Avatar
thanks, i already changed out my opti.
