What Have You Found???
Are you taking the roadway & wide tires into account in your question? Or are you talking about instability beyond that? (which can be considerable)
Based on what you have said, you should check your driveshaft as some people have problems with the balance of when stock. I would check the balance of your tires first however.
My car feels really stable at high speed and I don't even have SFCs.
FRONT LEFT RIGHT
Caster 4.6 4.9
Camber 0.3 0.5
Toe 0.00 0.00
Total Toe 0.00
REAR LEFT RIGHT
Camber -0.1 -0.2
Toe 0.05 -0.10
Total -0.05
Everything is within MFG specs, car is not lowered and is still sitting on stock suspension. Plans this winter are 12 Bolt and All new suspension... what do you guys think about KYB 5 way adjustable struts and shocks? with a 2'' drop?
They will at least let you know for sure about if it is balanced and you can mark that off your list. I would however go and get your tires balanced first.
Or you could just go to a scrap yard and get an 98+ alumminum one. There is a debate about alumminum compared to steel however when you get into higher horse apps. (It is over strength+ rotating mass) I think you would be fine with the 98+ one.
Cheapest route is the first option.
Hope this helps
Dave
