The TWS Engine Swap Thread
Old Aug 31, 2005 | 05:11 PM
solid95z's Avatar
Come Sunday, that car's gonna SH*T it's self....just like Todd
Old Sep 1, 2005 | 12:24 PM
Tony Shepherd's Avatar
Originally Posted by TWS
Tony Shepard and I are going to tune it. More like Tony will tune it and I will nod and say "uh-huh" at appropriate intervals as I look over his shoulder.
We are both getting started on PCM tuning, but Tony has access to a few tunes that were done professionally for very similar set ups (i.e stroker LT1's and LT4's) and we will look at those and tweak from there. In fact, we have one that is so similar, we should be able to load it and then fire up the car and drive it. It will take some refinement, of course, but should be pretty close right from the start.
We'll "street tune" it initially, then throw it on the dyno and tweak, then street tune again for driveability and tranny shiftpoints.
Im not a newbie on tuning.....been tuning speed density for about 6 years but the flash pcm's are new to me. It is really no different. Should be a piece of cake.
Old Sep 1, 2005 | 04:44 PM
TWS's Avatar
TWS
That's what I meant Tony. Sorry. Thanks for the clarification.
I'm sure we'll get that sucker running very, very well.
Old Sep 4, 2005 | 10:10 PM
disco192's Avatar
Looks good man...
Tony, thats some nice software you have there...
Old Sep 4, 2005 | 11:37 PM
Originally Posted by disco192
Looks good man...
Yes.........got it in the car and tuned and running today. I will let Todd explain and show pics. The software worked great. Had no problems whatsoever.
Old Sep 5, 2005 | 12:28 AM
solid95z's Avatar
Ditto....Everything went real smooth on the install. Motor looks AWSOME in the car also.
The car is absoutly SICK!!! Sounds ridiculious I am anxious to see how the car runs at the track
Old Sep 6, 2005 | 08:00 AM
TWS's Avatar
TWS
Yep. What Tony and Scott said. Motor is in and it sounds and runs nasty.
The torque is just evil.
Have to get one side of my true duals tweaked a bit. The exhaust side of the AFR heads is a bit different,causing my exhaust to hang a little bit off from the way it was before and now the driver's side taps the tranny crossmember. We'll get that moved before we do more tuning as it was causing a boat-load of KR during our "test passes" on HWY 183 that night.
Huge thanks again to Tony and Scott. We started spinning the wrenches on a "roller" car at 10:30 a.m. and at 6:25 p.m. I fired it up as a complete runner. Hooked up the torque arm and DS loop and went for a drive.
I'll post a few more pics soon.
Old Sep 6, 2005 | 10:04 AM
Ouija's Avatar
The Beast sounded sick (in a good way) last night when you dropped by to lend me a hand.
That car is going to be crazy.
When the tuning is complete, let me know because I want to go for a ride.
Old Sep 6, 2005 | 10:34 AM
BizZzatch350's Avatar
Moderator
Awesome, glad your keeping the blue beast. I'd almost move to Austin so I could get Tony to help me with my 93
Old Sep 6, 2005 | 01:31 PM
TWS's Avatar
TWS
Thanks guys. Yeah, I think it sounds mean, almost pissed off. Despite the fact that it is the exact same exhaust system, it sounds a bit deeper and bit louder than my 355 LT1 did.
It's just a huge roar when the loud pedal is pushed to the floor.
I'm going to bump up the fuel pressure a couple psi tonight and call Racetronix to get that Walbro and the install kit. I have 3 more projects already lined up to make this transformation complete:
1. Fuel pump
2. 12 bolt rear end
3. Wolf rear sway bar
Then, more dyno tuning and possibly putting in a cage. The car feels faster than 11.4's, but maybe I can go to the track with a full tank of gas or something to slow it down enough to keep from getting kicked out. That's a good "problem" to have, however.
As if I didn't get enough time under the car this weekend, Ouija installed his new built tranny and I stopped by to help him for a couple hours last night.
Old Sep 6, 2005 | 04:10 PM
TWS's Avatar
TWS
Some pics from Sunday's install.
Attached Thumbnails The TWS Engine Swap Thread-lt4-ready-front-small.jpg   The TWS Engine Swap Thread-lt4-ready-rear-small.jpg   The TWS Engine Swap Thread-lt4-going-.jpg   The TWS Engine Swap Thread-lt4-sitting-.jpg
Old Sep 6, 2005 | 04:14 PM
  #32
TWS's Avatar
TWS
And here she is, completely installed.
Timeslips coming fairly soon, but not soon enough.
Attached Thumbnails The TWS Engine Swap Thread-lt4-installed.jpg   The TWS Engine Swap Thread-lt4-installed-side.jpg
Old Sep 6, 2005 | 05:23 PM
  #33
Neil..........I will help you with your car anytime man!! Ill be like...................................... to it!!
Old Sep 6, 2005 | 07:57 PM
  #34
mikemodano9c's Avatar
looks good man!
Old Sep 6, 2005 | 10:19 PM
  #35
T/A KID's Avatar
Nice setup, not to STEAL the thread but Tony did you ever get your car dynoed with that single plain.
Old Sep 7, 2005 | 07:02 AM
  #36
Car is running. Broke my arm a few weeks back and it set me back a little while. I will reschedule for the dyno soon. Hopefully this month.
Old Sep 7, 2005 | 11:43 AM
  #37
TWS's Avatar
TWS
Just got an email from Thunder: The Brown Santa is on his way.
Attached Thumbnails The TWS Engine Swap Thread-racetronix-fp-kit-smaller.jpg
Old Sep 7, 2005 | 12:44 PM
  #38
Ouija's Avatar
And we're installing it when? (Since my stupid Torque Arm is still at the powdercoaters )
Old Sep 7, 2005 | 12:53 PM
  #39
solid95z's Avatar
I Say we put it in right after he gets that Wolfe sway bar
Old Sep 7, 2005 | 04:46 PM
  #40
Moderator
Jeeeze man how many time do I have to tell you, when they stunts are done by a trained profesional and do not atempt at home, they really mean it
