ARRRRG! Running out of solutions for this problem.
Old Aug 23, 2005 | 12:19 PM
97LT1's Avatar
Default ARRRRG! Running out of solutions for this problem.
I cant get my torque arm bolts out ,that go into my rearend. One comes down 1/4 of a inch and just spins after that. The other one closest to the tranny just spins in place. It is driving me nuts because it make noise at idle. I have tried to tighten them up real good but they just seem to not catch thread in there, so then that leaves me with a rattle.
I have taken a huge flat head screwdriver and wedged it between the bolt while tryin to loosen with socket with no luck. Anybody seen this or have any ideas.
I have bad feelings about these bolts and occasionally it seems when i take certain slow turns (like in driveway) I can hear the bolt slip. (odd noise)
I have gone over everthing else and these are the only loose things in that area. At worst i want to see what has happened and if i need to use a tap and die kit or another solution.
Old Aug 23, 2005 | 12:59 PM
ak95ta's Avatar
Umm..you are aware that there are nuts up on top of the rearend that those bolts thread into, right....
Old Aug 23, 2005 | 01:05 PM
ROCNDAV's Avatar
I usually install the bolts downward so the nuts are at the bottom. Either way, loosen the nut, until it is flush with the end of the bolt. Hammer on the nut a bit to see if you can pop the bolt up. WD-40 is your friend
Old Aug 23, 2005 | 01:21 PM
NXSLT1's Avatar
There are no threads in the torque arm or rearend, it's a bolt AND nut.
Old Aug 23, 2005 | 01:38 PM
infinitebird's Avatar
What kind of tool are you using? Get a large torque wrench if you don't have one (like a 1/2" drive).
Old Aug 23, 2005 | 02:30 PM
97LT1's Avatar
OMG I feel like an ***! It has been so long since i took it off that i forgot to look on top for bolts several times I am loosing my mind folks!
Sometimes the simple stuff can really boggle you.
Thank you so much , i dont know how long i would have been under there being retarded.
Old Aug 23, 2005 | 02:32 PM
NXSLT1's Avatar
lol I thought you might say that when you realized. We all do it man.
