tranny problem
Old Aug 28, 2005 | 12:05 PM
goodrich969's Avatar
Default tranny problem
Ok well i have a A4 in my 96 T/A and the tranny is actin weird. When i hit the gas at a red light or punch it from a roll i get a weird jerking feeling. Like i can feel it in the counsel. Yeah its jus like a weird jerking feeling, it dosent feel right. Could it be the tranny mount or something liek that? Someone please help me!!
Old Aug 28, 2005 | 12:56 PM
sssalah's Avatar
Either the tranny or the torque arm mount.
Old Aug 28, 2005 | 02:32 PM
but there isnt nething wrong with the tranny by the sounds of it?
Also, do you kno where i could get both of those, like a retail store?
thanks alot
Old Aug 28, 2005 | 03:33 PM
slowpoke96z28's Avatar
any parts store or gm dealership.
Old Aug 28, 2005 | 05:25 PM
which one should I get tho?
Old Aug 29, 2005 | 06:15 AM
sssalah's Avatar
Take a look at both mounts from under the car and replace the worn part, they are not necessarily both worn.
Old Aug 29, 2005 | 09:14 AM
ok what do they look like, are there any pictures or can you give a description of both, thanks alot!
Old Sep 5, 2005 | 08:22 PM
RUNanLt1's Avatar
Sounds to be a tranny mount. I broke a couple of them, dont just by a replacement. Make sure you get the Polyurthane(spelling), i beleive Energy Suspension makes them. You can find them at Autozone, salvo's etc, or any performance shops.
Old Sep 5, 2005 | 08:44 PM
Lt1FBoDy209's Avatar
99.9% sure its a tranny mount. same thing happened to me a while ago. a loud jerking noise kept coming from under the center consel when i gassed it or didnt drive like a granny. relativly inexpensive to fix, even at a dealer.
Old Sep 6, 2005 | 05:43 AM
Can I just instal it my self? IT dosent seem that hard, what would I have to do to install it? Thanks alot
Old Sep 6, 2005 | 07:55 AM
Speed Density's Avatar
hashtagBMW
Well your going to need some working room, i suggest gettin agood mechanic. ITs ont that hard to do, if you lift the car 6ft in the air, the mounts are very very noticable. ONe is from the tranny to the car, the other is the torque arm end closest to the tranny.
Old Sep 6, 2005 | 10:52 AM
Boshaft's Avatar
I had a 1993 Z28 before I bought my Corvette and the tranny mount went bad on two occasions. I had the same symptoms you are experiencing. It's not a tough job to handle yourself if you have some jackstands. You can buy the poly version of the mount for $15 to $20 and do it yourself, or pay $150 to $200 for a shop. I had a shop do it the first time mine broke and paid $211 . I did it myself the second time around for $15 . Chilton's/Haynes manuals can help you with the details of the labor. These books are available at just about any auto parts store.
Old Sep 6, 2005 | 12:31 PM
RUNanLt1's Avatar
Definately not necasarry to be 6ft off the ground unless you need to stand under there which you dont. I usually just jack the left side in the air, go underneith and take another jack and jack up to the tranny to hold it. Take the bracket that goes across the tranny off and replace the mount. Pretty easy.
Old Sep 6, 2005 | 01:03 PM
blind527's Avatar
A tranny mount is simple as hell to put in. 6ft. is not necessary.
Old Sep 6, 2005 | 05:13 PM
matrik's Avatar
Just put the front of the car on jackstands, put a piece of wood across the jack to spread the load, and jack up the tranny from the tranny pan just enough to remove the weight load on it. Then undo the 1 bolt on the mount, and the 2 that hold the cross member. Unbolt the mount, and reverse for install of new. Piece of cake
