Looking for Stock engine info.
Old Sep 5, 2005 | 08:51 PM
Nova5's Avatar
Default Looking for Stock engine info.
trying to input info into Dynosim, and the power curves are way off... indicated flywheel HP is below my RWHP. so i have some inaccurate data in it. Cam specs, flow specs, etc is what im looking for.
Whats in blue text can be changed, Yellow cannot.
Old Sep 5, 2005 | 10:20 PM
blind527's Avatar
This shows the stock cam specs Not sure if it was what you're looking for.
Old Sep 6, 2005 | 10:20 AM
Nova5's Avatar
Got the proper LSA/Center angle from that, thanks. Hardley affected the curves thou. 236 is RWHP and 290 RWTRQ.
Old Sep 6, 2005 | 04:21 PM
blind527's Avatar
This is for a 95, not sure how much difference there is also not sure how much more info you need.
Old Sep 6, 2005 | 04:30 PM
Nova5's Avatar
I'll see as i read through that...
BTW seems i didnt hit the apply button right.. here's what happened when i fed in stock cam data from the other link..
Errr... WTF? nearly 400TRQ right at the outset? me thinks somthing funky is up. I only included changed data.
Old Sep 6, 2005 | 04:35 PM
Nova5's Avatar
That data doesn't look like it will help me. However i will check with my engine mechanic friend and see what he says. I'm not the best at reading all this stuff. My head flow settings may be wrong and causing low curves or somthin.
Old Sep 6, 2005 | 04:50 PM
blind527's Avatar
I didn't think it would. I mainly posted it for your "other" needs in case you needed some other info that you didn't know.
Old Sep 6, 2005 | 04:52 PM
Nova5's Avatar
Headflow data.
