speed governor on 94 formula
Old Sep 17, 2005 | 03:56 PM
StrokerLS1's Avatar
Default speed governor on 94 formula
i have a 94 formula a-4. the car is governed at 108 which really sucks. i guess it was because my car came with h-rated tires from the factory, or thats what someone told me. anyways is there any cheap way of over riding the governor or do i have to get my pcm programed and get it deleted?
Old Sep 17, 2005 | 11:13 PM
catfSSh's Avatar
what does your speedo read up to. i think only the zrated ones read to 155. if it was governed from the factory it should read to 115 i think
Old Sep 17, 2005 | 11:32 PM
96capricemgr's Avatar
pcm reprogramming for a 94 starts at about $50 and will gain you a lot more than just the speed limiter raising so just do it.
Might be a way to wire the fuel pump to stay on even after the pcm commands it off(that is how the stock limiter works) but to wire something like that up safely and eff3edtively I bet you spend nearly what the pcm work costs and all it would gain you is complexity and the limiter defeat so it would be far from worth it.
Old Sep 18, 2005 | 02:59 AM
Bawls's Avatar
www.madtuner.com
Send him your PCM, have him work his magic.
Old Sep 18, 2005 | 04:55 AM
regorih383's Avatar
ya what does the speedo say
Old Sep 18, 2005 | 06:31 PM
StrokerLS1's Avatar
my speedo reads 115 so 50 bucks will eliminate that. were do i get it reprogramed? im in the atl aera if that helps...not far from gmmg. do they do that?
Old Sep 19, 2005 | 06:52 PM
Ed Wright's Avatar
9-Second Club
I'm afraid that is not how the PCM limits top speed, or RPM. It shuts the injectors off, not the fuel pump. It would take a while to burn off the fuel in the rails until pressure dropped far enough to kill the engine. Injector control is much more precise.
Ed
Old Sep 19, 2005 | 08:38 PM
I will trust you and that makes a whole lot of sense. The fuel pump is just what I had always heard and either way it is and feels like running out of fuel. It does eliminate any chance of hotwiring the fuelpump in order to bypass the limiter which brings us right back to pcm reprogramming. I find it increadibly frustrating how people try to avoid that part of modding a computer controlled powertrain.
As far as who does tuning, Ed Wright is the original LT1 tuning guru, madz28.com was already linked once, and pcmforless.com gets good reviews too and is who I am currently using. Especially with a stockish car you can not go wrong with any of these three. Ed is in or near Tulsa, Bryan of pcmforless is near Philly, and Ion of Madz28 is near Chicago. There are a lot of other places that can competently do this too those are just going to be the big 3 and all offer mailorder work so you don't have to bring the car to them.
Old Sep 20, 2005 | 10:27 AM
StrokerLS1's Avatar
cool thanks for the info ill prolly go with madz28
Old Sep 21, 2005 | 04:29 AM
30AnvZ28's Avatar
You can just unplug the tranny. Thats what my buddy did with his 94 Forumla. He also picked up a lot of power for some weird *** reason??? Thats FREE!!! Your MPH gauge wont work though.
Old Sep 21, 2005 | 08:36 AM
StrokerLS1's Avatar
unplug it where? will this cause any problems?
Old Sep 21, 2005 | 09:05 AM
30AnvZ28's Avatar
Unplug it right at the tranny, and he tucked it up, and used a zip tie to keep the tail from any moving parts. It didnt cause any problems other than his MPH gauge didnt work (since the speed comes from the tranny). Like I said, he even picked up some power for some reason.
Old Sep 21, 2005 | 05:27 PM
infinitebird's Avatar
I can do that for you anywhere around Atl for real cheap. $30 and I'll change whatever you want. I can meet you somewhere and have it done in a few minutes so you don't even need to take off your PCM or anything.
Btw, I just did this to my car (also a 94 TA) with no issues. Send me a PM if interested.
Old Sep 22, 2005 | 09:22 AM
StrokerLS1's Avatar
sent pm
Old Nov 17, 2019 | 04:41 PM
James Barnett's Avatar
then your transmission performance button won't work for a harder second gear shift
Old Nov 18, 2019 | 07:54 AM
dirtybob's Avatar
which plug, vss at the tailshaft?
Old Nov 18, 2019 | 08:16 AM
KW Baraka's Avatar
Way to respond to a 14 year-old thread, newbe.
KW
By Brett Foote | 2026-06-04 05:00:17
