What Size Injectors?
Old 09-18-2005 | 11:02 AM
SILVERZIP's Avatar
Default What Size Injectors?
I Have A 95 Camaro-lt1...ported Heads...headers- Gear And Converter..will Performance Injectors Help??? Thanks
Old 09-18-2005 | 12:25 PM
simple's Avatar
more then likely a step too atleast 30lb injectors would be good
but it would be best too datalog the car under WOT driving too see where the injector duty cylce is at and find out for sure
FYI, you can get new 30lb SVO (ford motorsport injectors) here at www.gefracing.com for $200 cheapest new on the net
a change in injector size will require reprogramming of the injector constant in the pcm
Old 09-18-2005 | 03:38 PM
96capricemgr's Avatar
Larger injectors will not help unless your stockers are either failing or are too small. If you did heads but no cam the stockers are large enough. As noted already injector size changes REQUIRE pcm reprogramming unless you want to overfuel it wash down the cylinders doing bore damage and then have the extra fuel get into the oil thin it out and wipe out the bearings.
Old 09-20-2005 | 11:53 AM
sssalah's Avatar
I think the stock size is fine is long as it's not cammed.
Quick Reply: What Size Injectors?
