Converter and Gears affect Tranny?
Old Sep 19, 2005 | 12:01 AM
Empire's Avatar
Default Converter and Gears affect Tranny?
Alright, I know this has been said but deal with it. I am looking to get a good converter and gears for my car which is my daily driver. I was thinking 3.73's and then I don't know what for the converter since I have little knowledge on the subject. But my main question is not truely what I should get but more or less would this add, a big added strain on my transmission?
Old Sep 19, 2005 | 07:02 AM
sssalah's Avatar
A high quality moderate stall converter aided with a tranny cooler shouldn’t be strenuous to the tranny at all.
Old Sep 19, 2005 | 09:27 AM
buffman's Avatar
and IIRC numerically higher gear ratios are easier on the transmission then numerically lower gears.
Old Sep 19, 2005 | 09:50 AM
Empire's Avatar
Oh ok, cool. If I get gears do I need to get new ring and pinion? I was thinking of getting these http://www.lmperformance.com/c/2/2.html but will these fit no problem to my practically stock car? And are the slp gears a good set or should I look into another brand/company? Also how much will this affect my top speed?
Old Sep 19, 2005 | 10:01 AM
slowmofo's Avatar
They will fit fine...as far as the top speed goes. My car with 3.42 will do over 140 I know that, but I don't really to go that fast. My friends car will only do around 125 with 3.73's because he has a th400 w/o OD.
Old Sep 19, 2005 | 11:03 AM
Camaro 0wner's Avatar
I had 3:73 gears put on my old camaro. (91 camaro RS 5.0 TBI) I liked it, but I hated it. My car ended up toping out at around 85! Although, it topped out around 125 before that. Still, it sucked. It was nice because I picked up about 3 tenths, but I would rather have that top end. I couldn't even run the quarter because of this. Personally, I thought it wasn't helping my transmission at all. Since I had an a4, it would get into OD so fast. Seriously, 30mph was like OD. I currently have 3:23 on my Z28 now (94 Z28 stock gears) and don't intend on changing them. Besides even if I did, I would gain like a tenth most likely. If you have 3:23 gears, I wouldn't bother. I had 2:73 when I made my switch.
Old Sep 19, 2005 | 03:57 PM
BigKap94z's Avatar
That makes no sense.
I say if you have 3.23's or less the swap would be worth it. If you have 3.42's I think you will be fine keeping them. A good converter is always a good idea, just make sure a good tranny cooler is also used to help with the extra heat created by the "slip" of the hi stall torque converter.
Old Sep 19, 2005 | 04:08 PM
Thanks for being a dick.
It does make sense because it happened. Don't act like you know the situation. If you want me to be exact I will. When the car was bone stock it topped out at 115mph. I put an eaton posi 3:73 gear on it and it topped out at 83.2 mph. I put it on the dyno and it wouldn't go past that. If he has a 2:73 gear now and changes it to a 3:73, he will probably top out around 125ish. His car can go about 150 or more now. It causes that much of a change with a car that has less top end to begin with. So, don't act like you know what's going on. Why would you think that made no sense anyway? Do you think a 5.0 TBI goes 150mph or something? Give me a break...By the way, I'm pretty sure manuals come with 3:42's and the A4's come with 3:23's. (not all of them, but some) My buddy's A4 97 Z came with 2:73. Wtf is your problem anyway, do you think I would make this **** up?
Old Sep 19, 2005 | 05:17 PM
Empire's Avatar
My brother has a 92 TA with the 5.0 TBI and he hits a govenor at 115 mph, did you not take it off? Note: Not attacking you in anway here just curious. Also how can you tell what kind of gears you have on one's car. Someone said check by the inside of the door, and what would I look for. I have a 94 TA, thinking of probably goin with 3.42, I am just lookin for a little more pep.
Old Sep 19, 2005 | 05:28 PM
BigKap94z's Avatar
WOW. I act like I know the situation, because I do..duh. What did you have a 22 inch tire on the car? Do yourself a favor, and find a good gear calulator online. Then put in the tire size, gear ration, and the tranny gears and you will also find your statement to be proposterous. For instance, 4l60's and 700R4's(which came in TBI auto cars), have the same OD gear of .70. With a 26 inch tire, 3.73 gears in overdrive the car can go almost 150MPH @ 5000 RPM's. Yes top speed has to do with power output as well as the gear ratio, but my buddies old LG4 RS camaro had 3.73's and had no problem going over 100. Hmmmm. Yes a change in gears will diminish some top end capability, but not nearly as much as you would like us to believe.
Hope this helps, Dick.
Old Sep 19, 2005 | 06:16 PM
Empire's Avatar
Just checked the car and found that I have 2.73s so now i just got to figure out which set of gears I should go with 3.42s or 3.73s. Any recomendations?
Old Sep 19, 2005 | 06:34 PM
aintno6's Avatar
Camaro Owner. I'm sorry but I'm guessing you must of had some tuning issues. Because there are lots of guys out there running 3.73's with a 700R-4 (the trans that came in your car), and didn't top out in the 80's mph range. Your car should of crossed the traps in 3rd gear without going into over drive. So unless you car was shifting at like 4 grand or somthing, and your wheels and tires were 23 inches tall, your situation is not making much sense. I don't doubt that it was happening. I'm just saying that 3.73's on a stock hieght tire shouldn't effect your top speed that drasticly. It sounds like a governor or shift point issue.
Old Sep 19, 2005 | 06:36 PM
96capricemgr's Avatar
Betting you skipped a step like reflashing the chip or something, maybe the kickdown. If the car topped out at lat low a MPH it was either your mistake or a mechanical problem even 4.10s will easily top 100mph eithout overreving due to overdrive. As noted run the math once with OD you can get VERY aggressive with rear gears before it hurts reasonbable topend.
Old Sep 19, 2005 | 06:54 PM
Empire's Avatar
Damn, my thread was hijacked by this fool Now is anyone willing to give any advice on 3.42 or 3.73s? When would the car be in rpm range at 70-80mph with both these gears?
Old Sep 19, 2005 | 07:00 PM
Speed Density's Avatar
hashtagBMW
BAH............get teh 4.10s
there nICe!!!!!
Old Sep 19, 2005 | 07:24 PM
lt11997's Avatar
I would get this kit http://www.thunderracing.com/catalog...&vid=4&pcid=68 . It has the ring and pinion gears,performance girdle, gear oil, GM limited slip additive, and all new bearings and seals(basically a whole new rear end). Very good choice if you car has 100,000 miles+.
Old Sep 19, 2005 | 07:43 PM
Empire's Avatar
Whats the difference between the motive and strange gears? As well as whats the difference 2 and 3 series carriers?
Old Sep 19, 2005 | 09:16 PM
BigKap94z's Avatar
The differences is one is for 2.xx gears, and the other was for 3.xx gears. To runa 3 series gear on a 2 series carrier you need a spacer. However companies make a thicker gear for the 2 series carrier so you can have 3.xx-4.10 gears with you factory 2 series carrier. I believe that is a good kit in that link as well. What do you mostly use the car for, i believe the 3.73's would be a good street gear, you dont give up alot of top end but may sacrifice a few MPG on the highway due to the raised cruising RPM's. Thats what i would get if i were u.
Sorry for helping to hi-jack, I just wanted to clarify to you that that other guys post was not accurate. I didnt want you to think you are gonna lose 50MPH on topend like he would lead you to believe.
Old Sep 19, 2005 | 10:31 PM
aintno6's Avatar
get the 3.73's you'll love em. And they are totally streetable, unlike what alot of the others think.
Mike
Old Sep 19, 2005 | 10:42 PM
Empire's Avatar
Yeah no problem. I saw that and I was like, I know I don't lose that much mph. Anyway my car is going to be for everday use and I use the freeway everyday so I don't want to lose my good cruising speed. Planning on doing all the bolt ons and then some. What would my rpms look like at 75 mph? So if i was to get the gears from Thunder Racing I would want to get the Strange 3.73 Gear Ratio, 2 series carrier? And whats the difference between the one I just stated and this one http://www.lmperformance.com/782/2.html ?
